Old 08-29-2013, 11:03 PM   #1
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Chase Bays ground kit, anyone install it?
So I've had this for awhile, looking at install. The twin power side isn't clear as would appear that the fuse box seems to be taken apart to pass through to alternator. This should be easy as pie right? It's not clear at all in fact and no instructions or downloadble |PDF as well. I have contacted vendor and well I don't expect them (ft86speedfactory) to figure it out for me or do an install vid and have not had any success with clear instructions back from Chase Bays on this kit. Therefore if "anyone" has instaleld this and can provide some clarity on the passing through part of the + side to alternator or how that is 100% supposed to be done I would be very gratefull!!!
Old 08-29-2013, 11:04 PM   #2
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
+1
Just ordered this kit and I'm confused about the same thing. Wondering why exactly it's better to have the alternator wire running back along the same wire that runs to the starter, versus going back through it's route through the fuse box.
Originally Posted by humfrz
I'm old and lazy
Old 08-30-2013, 12:49 PM   #3
Chase Bays
Chase Bays's Avatar
Drives: FR-S | 335i | S13
We will make a PDF to clear this up!
Chase Bays is offline   Reply With Quote
Old 08-30-2013, 01:08 PM   #4
Chase Bays
Chase Bays's Avatar
Are you guys against replacing the alternator lead? With our kit it's doing the same thing as it is on the fusebox (giving direct battery 12v) but in a more simple and better looking fashion. This is something we've done in all previous charge harnesses so we kept it going here. The lead simply unbolts from the fusebox and is removed from the loom.
There is the option of running our alternator lead under the intake manifold and to the alternator but retaining the factory fusebox to alternator lead as well. There isn't performance loss or gain here, just easier installation if you don't feel like untaping the alternator power wire until later.
Old 08-30-2013, 02:35 PM   #5
Calum
That Guy
Drives: 2013 asphalt FRS MT
Is your lead from the alternator to the fuse box fused?
Old 08-30-2013, 03:10 PM   #6
Chase Bays
Chase Bays's Avatar
Done.
Chase Bays Install Guide for CB-GT86-CHG/GND
Old 08-30-2013, 03:12 PM   #7
Raven604
Woah +1
Sent from my SGH-I337M using Tapatalk 4
Raven604 is offline   Reply With Quote
Old 08-30-2013, 03:18 PM   #8
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
+1 for humor and electrical jokes thruout.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 08-30-2013, 03:34 PM   #9
DJCarbine
Thupercharged
DJCarbine's Avatar
Could you guys provide a manual for my girlfriend? I still can't figure that shit out
2013 FRS
Vortech V3 11psi
Old 08-30-2013, 04:39 PM   #10
Chase Bays
Chase Bays's Avatar
Sometimes we wonder if people will get it. Thanks for getting it haha. Work should be fun right!?
Yeah man! Send us specs and we'll get it done.
Old 08-30-2013, 05:17 PM   #11
White64Goat
This kit is designed to do what exactly??
Old 08-30-2013, 05:33 PM   #12
Clipdat
Proud of BOXER
Clipdat's Avatar
The reason I got it is because I am sick of my idle dipping every time I roll up the power windows. Seems like the electrical system needed some bolstering so I will see if this addresses it.
I'm old and lazy
Old 08-30-2013, 06:49 PM   #13
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
Same boat. I get momentary dip for lights/windows/etc. After seeing the response time on that writeup I'll definintely be ordering this. Thanks for the humor and the fast responses guys!
Nightbringer is offline   Reply With Quote
Old 08-30-2013, 08:05 PM   #14
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
Let us know how it works, I'm getting annoyed at the idle drops every time I operate a control for anything too. I used to have a buddy club condenser/grounding kit, wonder if the condenser is unnecessary.
DoomsdayJesus is offline   Reply With Quote
chase bays, ft86speedfactory, ground
Chase Bays FR-S Chase Bays Member's Car Journals 325 12-16-2022 09:20 AM
KW, Cusco, GTSPEC, Tein, Megan, Whiteline...The best suspension products @ Chase Bays Chase Bays Brakes, Suspension, Chassis 7 02-11-2013 02:59 PM
Wilwood Big Brake Kit for Scion FR-S / Subaru BRZ at Chase Bays Chase Bays Brakes, Suspension, Chassis 15 02-11-2013 02:58 PM
Chase Bays Clutch Line, Full Replacement Chase Bays Transmission and Driveline 1 02-11-2013 02:57 PM
Chase Bays Braking Components Chase Bays Brakes, Suspension, Chassis 12 02-11-2013 02:57 PM
