Old 08-29-2013, 02:10 AM   #1
PITTFRS
Drives: 2013 FR-S Hot Lava
My sound system setup
Hello,
I have been doing some reading about the audio options for our cars as I am not happy with the stock audio like many of you. I actually like the stock pioneer head unit so I will be keeping that. For the speakers:
Front - alpine spr60c components. Deleting the 3.5 inch speaker in dash and just using tweeter. I will powr this with my alpine mrp-f250 amp bridged for 100 watts @ 4 ohms. This will work well as these speakers are rated for 110 watts.
Rear- Rewire stock 2 channel amp in trunk for use on the rear speakers. I think this will be a better idea than running another amp as this amp is rated at 140 watts peak so I'm guessing 70 per channel rms or lower. I will be replacing these speakers with alpine sps-400 4 inch coaxial speakers.
Trunk/subwoofer- I will be ordering a custom single sub enclosure box for an alpine sws-10d2 subwoofer powered by an alpine mrp-m450 amp.
I will be starting on this project as soon as my broken arm is healed which should be in a couple of weeks. I have not heard of anyone trying to reuse the stock 2 channel amp for the rear speakers. What are your thoughts on this? I think it will work quite well and put it to good use.
I'm going with all alpine because I've always had good experiences with them and I have a lot of the components from alpine already including the amps.
Feedback appreciated!
PITTFRS is offline   Reply With Quote
Old 08-29-2013, 12:49 PM   #2
PITTFRS
Somebody has to have some feedback on using the stock 2 channel amp that is in the trunk for the two rear speakers. Anyone?!
Old 08-29-2013, 03:13 PM   #3
thill
How are you going to cross everything over? If you want to use them (rears), get a bigger multi channel amp and then go active? Or just power them off the stock head unit? The stock 2 channel amp is crap IMHO. Especially for the rears which are mostly just fill.
Old 08-29-2013, 07:14 PM   #4
PITTFRS
You think that the amp in the factory HU is better than the one in the trunk? I figured the one in the trunk would be better. I can always run a set of coaxial rear speakers from the factory HU amp since it won't be used because of my 4 channel amp pushing the other speakers. I could probably even bridge the setup and push more power from the stock HU to the rear speakers. Do you think that sounds like a better plan?
Old 08-29-2013, 07:40 PM   #5
rupert
Audio & Bacon Junkie
rupert's Avatar
Drives: 2013 WRB BRZ Ltd
Just remember that the amp in the rear is 2 ohm.
Also, I think it has been talked about that the signal from that amp isn't flat. It has some level of bass boost.
rupert is offline   Reply With Quote
Old 08-29-2013, 09:00 PM   #6
PITTFRS
That would make sense since it powers the door woofers. I'll probably come up with a better solution then. I have been doing a lot of reading and it seems mostly everybody feels like this amp sucks and I'm guessing the amp in the HU probably isn't much better. Maybe I'll run my 4 channe amp not bridged and run the front two channels to the component speakers I'm the front and the rear two channels to the rear coaxial.
Old 08-29-2013, 09:59 PM   #7
thill
That is what I would do (fronts and rears off your 4 channel amp). The rears are just fill so I would not be too concerned about giving them much power.
Old 08-29-2013, 10:24 PM   #8
PITTFRS
That's probably what I'll end up doing. Also seems more simple that way. I will be ordering my custom speaker mounts tomorrow!
Post your sound system! scottman Electronics | Audio | NAV | Infotainment 2 06-12-2013 03:42 PM
Focal sound system john_jre Electronics | Audio | NAV | Infotainment 5 08-22-2012 08:53 AM
The quality of the stock sound system?? Jruex22 Electronics | Audio | NAV | Infotainment 15 08-13-2012 04:59 AM
86 Sound System Skorov AUSTRALIA 25 05-09-2012 04:51 PM
standard sound system rating NESW20 Electronics | Audio | NAV | Infotainment 3 12-28-2011 06:29 AM
