Old 08-27-2013, 01:56 PM   #1
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
Rough Downshift (bog?) from 3rd to 2nd...
6AT, driven mostly in manual mode, issue happens in both modes.
Only mods: Unichip EMS, K&N drop-in, Invidia Q300 catback.
I get a pretty rough downshift into second from third, but only when decelerating (to a stoplight, etc). It feels like an extra hard engine brake. If I give it a little throttle and manually downshift, everything seems buttery smooth. So far, I've cleaned the airbox and used some MAF cleaner on the sensor and not much changed related to this problem.
I have a CEL, but haven't gotten it read just yet. Planning on doing that on my way home tonight. Any ideas? I'll post codes as soon as I get them.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 08-27-2013, 01:59 PM   #2
xjohnx
Grip>Slip
xjohnx's Avatar
Try taking the unichip out of the equation and see if the issue persists.
Old 08-27-2013, 02:34 PM   #3
CaptainSlow
CaptainSlow's Avatar
Yeah, if your "only mods" list includes a reflash, I would consider eliminating that variable before assuming it's something in the transmission. Read the code, return to stock tune, and see if the problem goes away (or if the light comes back).
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 08-27-2013, 02:43 PM   #4
xjohnx
Grip>Slip
xjohnx's Avatar
The Unichip isn't so much a reflash as it is a piggyback, which I can see causing issues more easily than a reflash like ecutek. Piggybacks essentially sit between the ECU and the sensors on the motor and modifies the signals before passing them on in an attempt to trick the motor into performing in a certain manner. Definitely not the cleanest way to go about things, could easily confuse the ECU.
Old 08-27-2013, 02:48 PM   #5
enwave
enwave's Avatar
My only concern with that is that I've been running the Unichip for months, and the problem is only days old... Nothing changed in that equation which makes me curious. I'll definitely try removing it after I read the codes though!
Old 08-27-2013, 03:49 PM   #6
CaptainSlow
Hm, that is weird then...good luck!
Old 08-27-2013, 04:14 PM   #7
enwave
enwave's Avatar
I've been happy overall with the Unichip, but the only reason I'm doing it over a tune is because there aren't many Ecutek tuners (or even dynos) within a reasonable distance from me. Piggybacks are certainly not my first choice
Old 08-28-2013, 10:03 AM   #8
enwave
enwave's Avatar
Update: scheduled a service appointment.
CEL was unable to be read -- link/communication error with and without the Unichip. While trying with the engine on (first attempts were accessory mode) I noticed a rough idle and could see the shift knob visibly vibrating. I normally don't leave it idling that long, so I may just have never noticed.
I've seen the TSB for cam position sensors/rough idle and am suspicious that I am also a victim of that one!
I'll make sure to check back in after the service reps look at it tomorrow morning.
Old 08-29-2013, 12:01 PM   #9
enwave
enwave's Avatar
So, the dealership claims that the engine is running rich, and is attempting to blame that on the K&N filter (of course). But that seems counterintuitive -- the car should be running leaner on a higher flow filter if anything... Especially since I went ahead and pulled the MAF sensor and everything looked super clean. I'm guessing that the Unichip was adding a little too much fuel for my altitude, which is pretty high.
Funny thing is, though, that after removing the Unichip yesterday, my bog was completely identical. Maybe the ECM learned bad behavior? Or more likely, the CEL was unrelated to the light bog-like feeling I'm getting from 3rd to 2nd. They're resetting the unit today and I'll see if the ECU reset+lack of Unichip makes any difference whatsoever.
I may consider leaving the Unichip off, or grabbing Torque and making sure my A/F ratios look good and everything -- maybe even running a fuel out map on the Unichip if it reads rich.
I'm just still not convinced that this downshift bog is related to the Unichip or my airbox/air filter. We'll see in the next day or two as the ECU relearns... After an ECU reset everything seems initially okay.
EDIT: Dealership reported the following codes:
P0172 (Bank 1 Rich)
P117B (Fuel System Abnormal (Di))
P1170 (Fuel System Abnormal (Port))
Downshift rattle?? driftartist Issues | Warranty | Recalls / TSB 17 08-03-2013 10:00 AM
Thump happened on downshift into 2nd husker741 Issues | Warranty | Recalls / TSB 11 07-19-2013 12:07 AM
AT - Failed to downshift in manual mode abutterman Issues | Warranty | Recalls / TSB 26 03-14-2013 09:11 AM
transmission noise (when going to downshift) Hotlava86 Issues | Warranty | Recalls / TSB 5 09-03-2012 10:04 PM
Paddle shifting automatic downshift FR-YES Scion FR-S / Toyota 86 GT86 General Forum 15 08-06-2012 09:18 AM
