Old 08-27-2013, 07:32 AM   #1
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
DIY Request- Port Injectors
Thanks
Sent from the moon
Old 08-27-2013, 08:43 AM   #2
charged86
charged86's Avatar
Well follow the DIY for pulling the fuses for fuel pump. Then try and start vehicle to get pressure out. Make sure engine is cold. Or carbecue could happen. Remove the big bulky steel covers the passenger side is the hardest one. I removed the upper brace on the driver side to make room. You should see the fuel rails at this point there are 2 12mm socket head bolts per side.
Also dezoris in his direct injector vid should really be of some help. I would have a magnet on a stick ready. I dropped a few bolts when I did mine. Dont over tight dosent take much torque to strip out the aluminum threads in the head
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
The Following 2 Users Say Thank You to charged86 For This Useful Post:
Sportsguy83 (08-27-2013), suaveflooder (08-31-2013)
Old 08-27-2013, 02:08 PM   #3
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by whitefrs View Post
Thanks
Are you actually going to DIY it? It really isn't too difficult. I prefered disconnecting the fuel lines during my install of the injectors. It is basically just removing the covers and then unbolting the fuel rails.
Old 08-27-2013, 02:58 PM   #4
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Yes dude
Its time for me to start working on my own shit
Thats how i found out about the fuel pump
Sent from the moon
The Following User Says Thank You to whitefrs For This Useful Post:
Rinzler_ft86 (03-09-2016)
Old 08-29-2013, 10:11 PM   #5
charged86
charged86's Avatar
Yes dude
Sent from the moon
well if you are on the moon take a spin in the lunar roving vehicle.
The Following User Says Thank You to charged86 For This Useful Post:
Sportsguy83 (09-28-2013)
Old 08-29-2013, 10:13 PM   #6
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Fuck taking a spin, i need to boost it first lol
Sent from the moon
The Following 2 Users Say Thank You to whitefrs For This Useful Post:
charged86 (08-29-2013), Sportsguy83 (09-28-2013)
Old 08-29-2013, 10:21 PM   #7
charged86
charged86's Avatar
Sent from the moon
I lolled that thing is slow as balls but gets hella airtime
Old 08-29-2013, 10:37 PM   #8
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Full blown kit on it and that shit will flyyy
Sent from the moon
charged86 (08-30-2013), Enalband24 (03-11-2016)
Old 08-30-2013, 10:29 AM   #9
charged86
charged86's Avatar
Sent from the moon
did you get your injectors done
Old 08-31-2013, 10:49 AM   #10
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
I installed my 1000cc injectors and i think i did everything correctly
Car didnt start the first time, i figure there was no pressure.
It did the second time but rpm goes up and down like fast 1-2k and got Code p062D
could i have done something wrong?
Old 08-31-2013, 12:06 PM   #11
charged86
charged86's Avatar
Well what size injectors did you have installed when you received your tune.
Old 08-31-2013, 07:55 PM   #12
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Did you flash your ECU with a ROM for the twice as large injectors?
Old 08-31-2013, 07:56 PM   #13
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Yes
I dont know wtf is wrong dude
Car stalls and Blinking Cel
Sent from my iPhone using Tapatalk - now Free
Old 08-31-2013, 07:58 PM   #14
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I would guess that your tuner doesn't have the settings correct for the injectors then. What is your AFR at idle? How do your short term fuel trims look at idle? Did you make sure the injectors are seated well and there are no leaks? Did you use the same fuel rail spacers as the Full Blown 550cc injectors?
Injectors installation kaybee123 Forced Induction 27 03-08-2016 09:26 PM
So what exactly will aftermarket feul injectors do to my frs Frsexxxy Engine, Exhaust, Transmission 8 03-10-2013 12:28 PM
Deatschwerks BRZ/FR-S Fuel Injectors! RallySport Direct Engine, Exhaust, Bolt-Ons 2 09-07-2012 06:29 PM
