Old 08-23-2013, 06:05 PM   #1
torqdork
torqdork's Avatar
Drives: RV-7
Are Carbotech XP10/XP8 pads position sensitive?
While installing the XP10/XP8 Fr/Rr I recall a letter, possibly an "I" stamped on some pads, but no directional arrows or other markings. Does it matter how they're installed forward/backward/inner/outer?
Possibly related to this, after proper bedding in at the local airport the ABS has come alive under hard braking with Potenza RE-11A's. I'm wondering if pad placement has anything to do with it, or is it due to higher performance pads generating more clamping force or something expected with XP series modulation? The ABS was nowhere near as active with OEM pads.
TIA...
torqdork is offline   Reply With Quote
Old 08-23-2013, 06:34 PM   #2
No, they're not.
You're getting more ABS action because you're braking harder, but with staggered compounds. The same pedal pressure will generate substantially more pedal pressure (nearly double the friction), and the EBD is trying to compensate for the difference in braking at the front and rear axles.
Effectively, you can step on the brake less to get the same braking force, so you should have a nice big range for modulation.
Old 08-23-2013, 06:45 PM   #3
OrbitalEllipses
Drives: Attitude
Do you recommend this one:
Or this one?
Old 08-23-2013, 08:25 PM   #4
torqdork
torqdork's Avatar
Drives: RV-7
No, they're not.
Thanks Mike, makes sense since it's the fronts that are trying to lock with the same pedal pressure as OEM pads.
Old 08-23-2013, 08:31 PM   #5
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
I'm running xp8's front and rear and my abs is for sure more lively.... Especially since I am on stock tires still hahah. Totally normal my friend.
TouchMyHonda is offline   Reply With Quote
Old 08-23-2013, 10:52 PM   #6
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
So why the staggered compounds?
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
FS: Carbotech Performance Brakes, CT929-XP10 (Subaru BRZ/Toyota FRS) Front Brake Pads xman11 Brakes, Suspension, Chassis 3 10-04-2013 02:23 AM
FREE Carbotech XP10 Front pads (used) Dave-ROR Brakes, Suspension, Chassis 41 12-04-2012 02:55 PM
Carbotech pads in Canada? BatStig CANADA 1 07-15-2012 08:56 AM
Carbotech Pads & Equivalent Sizes Black Tire Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-02-2012 10:43 PM
