Old 08-23-2013, 04:22 AM   #1
etherealfall
Drives: Toyota 86 GTS Storm Black
18x9.5 wheels
Just bought 18x9.5 wheels - plan is to lower the car eventually but for now, it will stay stock height (lowering with coils)
Can anyone guide me regarding the need to roll fenders + any camber adjustments necessary to remain at a good alignment? (relative term)
Also, will I definitely clear front strut on stock suspension? I know on coils I will be fine.
Finally, what are some good tyre recommendations (aspect ratio + width); looking to run 245s but may suffer some a bit too much stretch? My reluctancy to go to 255 is two fold - unnecessarily wide for street driving + added weight and the possibility of not clearing front struts with stock suspension?
Thanks!
etherealfall is offline   Reply With Quote
Old 08-23-2013, 06:38 AM   #2
FR-S Matt
Thanks!
I ran 18X9.5 on stock suspension with 245/35's for a bit while I waited on my coilovers to come in. Clearance is about | | to the front spring, literally, but can be done. 255 will rub in front for sure. 245's aren't very much stretch at all on 9.5's. If any, it's very little.
I recommend planning on coilovers though. Made a massive difference in my handling for me even after dropping.
Edit: Figured I should add my offset and its +38
Old 08-23-2013, 08:02 AM   #3
PradiG
Drives: Fr-s
Thanks!
Whats the offset on your wheels?
i run 18x9.5 +29 front, on coilovers, no fender mods, but close to front fender. Im also running 225/40.
Once you lower you will get natural camber. More natural camber depending on how low you go.
Cant comment on stock suspension
PradiG is offline   Reply With Quote
Old 08-23-2013, 08:32 AM   #4
etherealfall
Im at +34 offset. I know +38 is EXTREMELY close but I would imagine you are limited in tyre selection for anything in the 9.5 range. If you're close on coilovers with +29, fender work may be necessary but what I can't really change is the space to the strut - any idea on how much clearance you have? I can always roll and pull fenders but I can't imagine I'd need to
Old 08-23-2013, 08:35 AM   #5
etherealfall
I'm set on coilovers for several reasons but for reference, what offset were you?
Old 08-23-2013, 08:41 AM   #6
FR-S Matt
+38
Wheel Directory: Cosmis XT-005R 18x9.0 +25 HarrisRees Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 37 07-20-2018 09:14 PM
Wheel Directory: XXR 530 18x9.75 +20 alexfrspr Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 02-09-2017 08:02 AM
Unknown Wheels 18x9.5 +40 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-24-2013 03:54 PM
FS: 18x9 Cosmis 005 wheels and tires Vigilant Motorsports Wheels and Tires 0 06-22-2013 04:02 PM
