Old 04-27-2013, 09:29 PM   #1
gvan1998
Drives: Blue FRS
TPMS Sensor Issues
I have set of Honda tpms sensors that came out of an Accord. Will they be compatible with the FRS?
gvan1998 is offline   Reply With Quote
Old 04-27-2013, 10:41 PM   #2
dsgerbc
Drives: BRZ(sold), STI
Most likely no.
dsgerbc is offline   Reply With Quote
Old 04-27-2013, 11:11 PM   #3
gvan1998
Drives: Blue FRS
Only reason I asked is because aftermarket tpms sensors are comaptible with both Hondas and toyotas
Old 04-28-2013, 06:55 PM   #4
THA STI GUY
DRIFT BUILD
THA STI GUY's Avatar
Drives: 2013 FRS
They might if they are the same frequency as the stock ones but most companys use all different ones to not run into this problem with other cars on the road other wise you would be picking up other peoples tires driving next to them
THA STI GUY is offline   Reply With Quote
Old 04-28-2013, 07:48 PM   #5
LavosTRD
Toyota Master Tech
Drives: Whiteout MT
post up a picture of them and i will tell you
LavosTRD is offline   Reply With Quote
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 03:20 PM
FS: Stock Wheels+Stock Tires+TPMS sensor Pin Flare Wheels and Tires 1 03-26-2013 12:07 PM
TPMS Sensor Part Number or Compatibility civicdrivr Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 11-07-2012 02:06 PM
Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? Ahz Issues | Warranty | Recalls / TSB 9 11-06-2012 09:25 AM
Bad MAF Sensor paulieblaze Scion FR-S / Toyota 86 GT86 General Forum 3 08-23-2012 11:34 PM
