Old 08-22-2013, 12:09 AM   #1
teamred
Drives: firestorm scion frs
anyone running 255/40/17s? 1"drop?
im lowered on rce springs and wondering how 255s will fit, I have some 17x9+35 I need rubber for and am wondering how much rubber I can fit without rubbing. pic's would be greatly appreciated. thank you
teamred is offline   Reply With Quote
Old 08-22-2013, 12:11 AM   #2
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
You are good to go on that setup.
One more...
FT-86 SpeedFactory is offline   Reply With Quote
Old 08-22-2013, 12:13 AM   #3
rainmonkey
Drives: BRZ - Dark Grey
Didja have to roll fenders?
rainmonkey is offline   Reply With Quote
Old 08-22-2013, 12:38 AM   #4
teamred
ft-86 looks awesome ill go ahead and get em then thank you
Old 08-22-2013, 01:04 AM   #5
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I'm on 255s and a lot lower than that on coils. 17x9 et40.
Old 08-22-2013, 03:22 AM   #6
TRD_86
Drives: 2013 86 white
255 fit the x9 perfectly but I think wheel +35 will poke a little. Is it right?
TRD_86 is offline   Reply With Quote
Old 08-22-2013, 07:33 AM   #7
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Regarding rear fitment:
From my experience w/ 17x9 +35s & 255s--I had some rubbing in rear on one side. My rear camber was wonky from the factory (-1.3 & -2) & it rubbed on the -1.3 side. I've since corrected that w/ adjustable rear LC arms.
My conclusion is that if you have -1.7 or more on both sides in rear, you should be fine.
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 08-22-2013, 10:24 PM   #8
Dephective
Drives: '13 Whiteout FRS
I'm running 255/35/17 on 17x9.5 +38 RPF1. I get rubbing on both rears and I'm about the same height in the rear as the red one posted above. I can't hear it when it's happening but you can see the evidence on the tire. I think I'm about -1.8 in the rear. I've got a set of RacerX rear LCA on the way to fix this.
Previous:
'01 Accord-daily
'93 Rx7-fire breathing track monster 545hp 397tq 2300lb.
'06 Mazdaspeed6 one helluva love-hate relationship
Dephective is offline   Reply With Quote
Old 08-09-2015, 11:32 PM   #9
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
One more...
Will 255s on 17x9 +35 fit with RCE Yellows and 3 degrees camber? Or will the tire rub the spring perch? Assume 1.5 degrees with the camber bolt and 1.5 with the top hat.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
"LED Strip Daytime Running Lights and Valenti Tails --- Shipped Anywhere!!" F-T Exterior Parts - Lighting 169 08-20-2016 01:15 PM
"LED Strip Daytime Running Lights and Valenti Tails --- Shipped Anywhere!!" F-T Exterior Parts - Lighting 187 05-15-2013 01:07 AM
What is the "best" drop in filter? Osiris Engine, Exhaust, Transmission 10 04-04-2013 04:39 AM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
1" drop yomchi1989 AUSTRALIA 12 09-29-2012 05:13 AM
