Old 08-21-2013, 12:48 AM   #1
mikeTee
Yup.
mikeTee's Avatar
Drives: MT Subaru BRZ '13
19x9.5 with +38!? All Around
Thinking about getting some new wheels in 19x9.5. I already know the pros and cons of going with 19's, this thread is more so just to find the optimal fitment. I plan on doing the wheels and suspension at the same time, as a 19x9.5 setup is impractical on stock suspension, but what do you guys think about 19x9.5 +38 running on 245/35/19 wheels? I plan on lowering it an inch at a minimum to two inches, and I believe lowering the car adds negative camber. I know RavSpec did their 57xtreme 19x9.5 all around with a +43 offset and they claimed it would fit a 245/35/19 wheel. Played around on http://www.frsproject.com/tire_size.php and it looks good on paper, any thoughts? The manufacturer of the wheel offers offsets from +4 to +42 if +38 is cutting it too close on the front. I know a lot of people are doing 18x9.5 +38 as well, worst case maybe I'll go with 18's, but my heart is pretty much set on 19's.
Thanks in advance!
mikeTee is offline   Reply With Quote
Old 08-25-2013, 02:02 AM   #2
fatpwr
Drives: 2013 Raven FRS
depending on how much camber you get from the drop. you should be able to clear perfectly fine. i don't see why you wouldn't when guys with 18x9.5 +35 with 245/40 fits fine with lowering springs only.
fatpwr is offline   Reply With Quote
Wheel Directory: Rotiform BLQ 19x9.5 +?? igorot Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 10-28-2015 06:21 PM
Wheel Directory: Five:AD R5:F 19x8.5 +45 / 19x9.5 +35 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 08-21-2014 11:09 PM
Wheel Directory: Varrstoen ES2.2.2 19x9.5 +30 / 19x10.5 +30 FRSGIRL❤ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 01-26-2014 10:11 AM
FS: Rotiform SNA 19x9, 19x10 FRS GT Wheels and Tires 21 04-03-2013 11:10 PM
Wheel Directory: HRE 540 19x8.5 +?? / 19x9.5 +?? howiedoit Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 01-15-2013 01:56 AM
