Old 08-18-2013, 01:38 PM   #1
CivicEx13
Drives: swp brz
Help with Megan springs
I just installed my springs and the fronts are great but the rears are clunking like crazy I noticed they were really shorter then the stock springs but idk if that is the problem everything is tight and torqued right any help would be great
CivicEx13 is offline   Reply With Quote
Old 08-18-2013, 01:40 PM   #2
MPI_Jack
Drives: '13 FRS, '02 BMW 530i(550HP, turbo)
How did you loosen and tighten the rear shock top bolt?
MPI_Jack is offline   Reply With Quote
Old 08-18-2013, 01:41 PM   #3
CivicEx13
Drives: swp brz
With Allen head and the pass through sockets
Old 08-18-2013, 01:44 PM   #4
CivicEx13
Drives: swp brz
The springs didn't even come in contact with the top hat when everything was tight
Old 08-18-2013, 01:45 PM   #5
CivicEx13
Drives: swp brz
But I figured once the weight of the car was on them they wouldn't move
Old 08-18-2013, 03:54 PM   #6
CivicEx13
Drives: swp brz
Fixed it top hats were not getting tight due to no more thread cause the springs were shorter put 2 washer under the nuts on each side in the rear and everything got tight and no more clunking
Megan Racing Lowering Springs for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 161 01-10-2015 12:15 PM
Megan Racing Springs stefmiesterb Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 04-16-2014 01:59 PM
**Megan Racing Coil-over, Springs, Control/Trailing Arms Special** ProPartsUSA Brakes, Suspension, Chassis 2 07-17-2013 07:16 PM
Megan Coilovers delusional Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-29-2012 05:32 PM
