Old 07-16-2013, 11:28 AM   #1
stefmiesterb
stefmiesterb's Avatar
Drives: B8 A5
Megan Racing Springs
I cant find any reviews on the orange Megan Racing drop springs. Does anyone have them and want to chime in?
http://www.redline360.com/megan-raci...rz-MR-LS-SFR12
stefmiesterb is offline   Reply With Quote
Old 07-16-2013, 11:38 AM   #2
Racecomp Engineering
Off the top of my head, a 1.75 inch drop up front leaves you with 0.75 inches of compression travel...and that's including the bumpstop. No. Thanks.
- andy
Old 07-16-2013, 11:49 AM   #3
wparsons
wparsons's Avatar
And, these are barely stiffer than stock so you'll be on the bumpstop constantly.
These are 146/230, FRS stock is about 128/212.
Definitely no thanks.
flickr
Old 07-16-2013, 11:52 AM   #4
VIXEN
Girl with the Purple FR-S
VIXEN's Avatar
Drives: Purple People Eater
Get the Megan Street coils... affordable and better than springs. Thats what I'm going with.
#facebook #instagram #wrapspecialties
"She don't believe in shooting stars, she believes in shoes and cars."
VIXEN is offline   Reply With Quote
Old 07-16-2013, 12:40 PM   #5
qoncept
qoncept's Avatar
Or don't, because they are junk.
qoncept is offline   Reply With Quote
Old 07-16-2013, 01:31 PM   #6
VIXEN
VIXEN's Avatar
Everyone is entitled to their own opinion. Some people cant afford expensive Coils. It depends if he's just dropping it to look low or for performance.
Anyway... Read this thread.. it talks about them.
http://www.ft86club.com/forums/showthread.php?t=41305
Old 07-16-2013, 01:46 PM   #7
vividracing
vividracing's Avatar
When I was running my 240 way back in the say, I used megan products because they were cheap and got the job done. However I have a nicer car now and will only use products that will compliment it nicely. If you are just looking for lowering springs let me know and I can work with you on a pricing that matches your budget.
Jacky
vividracing is offline   Reply With Quote
Old 07-16-2013, 01:54 PM   #8
This isn't really even a question about the quality of Megan products or them as a brand. You just can't lower this car 1.75 inches on a fixed perch strut and expect it to be "good." Acceptable for you on smooth roads? Maybe. But it's not going to handle well. And it's not going to ride well if there's any sort of bumps. I'd say the same if it were Swift, Tein, RCE, H&R, whatever.
If you really want that much of a drop, I'd recommend coilovers or deal with a subpar driving experience.
- Andy
Old 07-16-2013, 03:55 PM   #9
Calum
That Guy
Drives: 2013 asphalt FRS MT
- Andy
Subpar, boarding on dangerous.
I'm curious how much camber and toe correction would result from the much drop?
Old 07-16-2013, 04:01 PM   #10
stefmiesterb
Drives: B8 A5
This is the answer I was looking for.
- andy
Old 04-14-2014, 01:33 PM   #11
mweidner311
Drives: N/A
Phew glad I read this post before I pulled the trigger on these looks like ill go with Eibach sportlines instead.
mweidner311 is offline   Reply With Quote
Old 04-14-2014, 01:51 PM   #12
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
If you can't afford quality products, don't modify. End of story.
Suspension is a vital part of the safe operation of a vehicle. FUBARing the geometry and damping performance to get a look is neither wise nor safe. Low and slow doesn't hold water when you need to avoid an incident on the freeway.
Cheers
Nathan
SubieNate is offline   Reply With Quote
Old 04-14-2014, 02:10 PM   #13
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Megan racing street coilovers, I found for $679. That's $170 per corner. Does that seem right for a coilover that will hold together? For comparison, the cheapest Bilsteins (B14) are $250 per corner, from a much more reputable and knoweldgeable company...based purely on safety concerns.
For that price, they will have to produce each corner for less than $170 to make any sort of profit. Are they cutting any safety corners? Why are other coilovers between $850-1000?(entry level)
These are the questions to ask when buying coilovers.
Old 04-14-2014, 03:18 PM   #14
qoncept
qoncept's Avatar
There's no reason to expect they wouldn't be safe. They shouldn't break. The difference in cost is going to be in better damping.
Megan Racing Lowering Springs for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 161 01-10-2015 12:15 PM
**Megan Racing Coil-over, Springs, Control/Trailing Arms Special** ProPartsUSA Brakes, Suspension, Chassis 2 07-17-2013 07:16 PM
Megan racing ez coilovers iHeartmyFR-S Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 01-10-2013 09:48 AM
Megan Racing Coilovers. greenguy101 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 09-24-2012 11:13 PM
Megan Racing has a FR-S..Catback to come! MarkRacerX Engine, Exhaust, Transmission 4 06-26-2012 11:44 AM
