Old 08-14-2013, 09:52 AM   #1
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
is it ok to turn the AC on and off all the time?
i have the brz limited, so every time i turn on the fan, the AC light also turns on. I don't need the air to be de-humidified so i turn off the AC right away. Is this bad when the AC starts and i shut it off right away?
chenshuo is offline   Reply With Quote
Old 08-14-2013, 10:00 AM   #2
gily25
Drives: Silica BRZ 6MT
Depressing the button over time will eventually wear it out but unless you're shutting it off 3 times in an hour or something ridiculous I don't see it as being an issue. If the car reached the temp in the first few minutes and shut the compressor off the same thing would happen.
Can you try just setting the temp a little higher? Our Lancer has the auto HVAC and we set it for the mid-temp just so the compressor doesn't come on during start-up unless it's crazy hot out.
gily25 is offline   Reply With Quote
Old 08-14-2013, 10:13 AM   #3
spyingwind
Drives: White '17 86
The compressor is designed to turn off when the engine is under heavy load, also it is deferent from your house a/c compressor in that it is designed to not overheat or seize when toggled on and of over a short period of time.
Just set the temp where you want it and let the electronics do the rest.
spyingwind is offline   Reply With Quote
Old 08-14-2013, 10:33 AM   #4
Suberman
Drives: Subaru BRZ Sport Tech Satin White
If you have the climate control it remembers how you left it when you switched off. If you switch off the AC in the automatic version it stays off until you select AC or AUTO.
In Canada the automatic climate control came on the Sport Tech trim, top model only.
Still, I am puzzled as to why the AC would switch on if left off when you switched off the car. Are you sure you aren't looking at the recirc light/button. That comes on in hot weather when you switch on.
Suberman is offline   Reply With Quote
Old 08-14-2013, 10:34 AM   #5
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
Perfect
BRZfan is offline   Reply With Quote
Old 08-14-2013, 01:08 PM   #6
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
The recirc light comes on only when its hot but the AC light comes on everytime when i turn on the fan even if i turn off AC before i shut off the car.
What temp do u guys set at so that AC light doesnt turn on?
Old 08-14-2013, 01:12 PM   #7
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
I noticed this too, every time I turn the fan on the A/C will also automatically turn on. Sort of just used to turn knob and push the in-car circ to off and a/c to off now.
Myv is offline   Reply With Quote
Old 08-14-2013, 10:11 PM   #8
immortal_suby
Drives: 2015 BRZ Limited 6MT
I do the same thing in the morning. Twist the fan knob for some air, then tap the recirc and AC buttons right away to shut them off.
2015 BRZ , 1992 SVX LSL, 2019 ASCENT
immortal_suby is offline   Reply With Quote
Old 08-14-2013, 10:24 PM   #9
Luis_GT
What temp do you have your hvac set to? The A/C button stays lit, but it won't run unless the interior temperture of the car is above what you set the hvac to... BTW, A/C cools the air, it dehumidifies to a point, but it isn't a dehumidifier as it leaves about 40 to 60% of relative humidity...
Old 08-14-2013, 10:43 PM   #10
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
You're turning on the car with the defrost on. Defrost = A/C on.
I've never had any issue with the A/C being on when first starting the car, as I always blow the fan on max for a few seconds to get rid of excessive condensation buildup on the coils so it doesn't smell when I get back in the car.
-alex
Old 08-16-2013, 10:57 PM   #11
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
Are you turning the system off? I just leave the fan on low setting when I turn off the car. When I turn the car back on, the settings are exactly how they were when I turn it back on.
If you turn off the system, you have to hit "auto" to have it come on? Then it might decide to put the AC on depending how its set up? Not sure... but again, I just leave it and turn the AC switch on/off when I want.
ashtray is offline   Reply With Quote
Old 08-17-2013, 10:04 PM   #12
Brzetto
Drives: 4 wheels
Just to be clear, what RPM qualifies as heavy load so the compressor turns off?
Brzetto is offline   Reply With Quote
Old 08-18-2013, 12:41 AM   #13
spyingwind
When sitting still, in neutral, and you floor the accelerator. The compressor will not turn off, but if you engage the clutch and floor it. The compressor will turn off because you are requesting more power from the engine.
Normally I can't tell when the compressor turns off other than feeling the cool air turning to warm air, but that that is a delayed test.
I am sure that it turns off after 4-5k RPMs or so, but not for sure. At least not without looking at the ECU's code.
Old 08-18-2013, 12:45 AM   #14
Brzetto
Drives: 4 wheels
I'm still about 200 miles away from break in period so I won't be going over 4k for at least another month or two.
Tap Turn thorlius Electronics | Audio | NAV | Infotainment 304 09-29-2016 03:21 PM
My turn at the curse - Hit and run Rayme Scion FR-S / Toyota 86 GT86 General Forum 53 08-19-2013 10:43 PM
My turn. =( jonbonazza Scion FR-S / Toyota 86 GT86 General Forum 28 07-15-2013 02:57 PM
Voice Commands with new turn by turn in IOS6? jadewbj Electronics | Audio | NAV | Infotainment 0 09-21-2012 10:11 AM
