Old 02-05-2012, 12:54 AM   #1
Asphalt
Differences In Types of Headlights/Lighting
Can someone explain the differences between various types of headlights?
for example the lighting in halogen projectors vs HID system projectors? what is different?
bi-zenon, PNP,retrofit........WHAT DO THEY MEAN!? and how do they work etc...i don't know much about lighting(all i ever did was a 50$ HID system off ebay...it wasn't that good). What are the different types of lighting and how you order them in highest satisfaction?
Asphalt is offline   Reply With Quote
Old 02-05-2012, 01:37 AM   #2
old greg
Rocket Surgeon
Drives: PSM GGA OMG
The bulbs. The reflectors and lenses will be shaped a bit different, but they are functionally the same.
Bi-Xenon: HID projector with a cut-off shield that can be flipped down electronically to turn a low beam into a high beam.
PNP: Plug and play. Presumably into your stock wiring harness.
Retrofit: Inserting salvaged HID projectors into your OEM headlights. Usually involves an oven, power tools and a weekend or two in the garage (or UPS and your checkbook).
For anything else, check out HIDplanet.
old greg is offline   Reply With Quote
Old 04-03-2012, 10:22 AM   #3
robotvoice
Drives: 07 STI
The internal reflector bowl and cutoff shields are different between a halogen projector and an HID projector. They look the same on the outside but are very different on the inside. This is why people make the mistake of jamming HID kits into halogen projectors thinking they will work just fine, when in reality the output is horrible. Halogen projectors also have a certain amount of "glare" built into them to help illuminate road signs at night and putting HID bulbs into halogen projectors just intensifies this glare to unsafe levels at night for other drivers on the road.
robotvoice is offline   Reply With Quote
Old 04-03-2012, 12:31 PM   #4
Longhorn248
Hook 'em
Longhorn248's Avatar
HID headlights are going to have a higher output in lumens (how the amount of light is measured) over traditional halogen lighting.
Please don't buy the $50 kits off e-bay they're dangerous for other drivers and could potentially fry the wiring in your car.
I also recommend HIDplanet for all your lighting questions and needs.
Longhorn248 is offline   Reply With Quote
Old 02-20-2013, 05:23 PM   #5
jjdrivesajazz
Drives:
you can check out our all new 22w high power LED headlight bulb replacements, alternative to HID's with less clutter and hassle, simple bulb replacement and yeilds 1200lm/bulb
jjdrivesajazz is offline   Reply With Quote
Old 02-20-2013, 05:26 PM   #6
MmmDieselFumes
MmmDieselFumes's Avatar
Drives: .
Any links for going this route? What's the output of the stock lights?
Sent from my Nexus 7 using Tapatalk 2
MmmDieselFumes is offline   Reply With Quote
Old 02-21-2013, 02:01 AM   #7
jjdrivesajazz
Drives:
http://www.ft86club.com/forums/showthread.php?t=27891
Old 02-21-2013, 07:49 AM   #8
MmmDieselFumes
Drives: .
Holy crapple! That's awesome. You pretty much have me sold, though looking at the pictures, how are these installed? I know you say they're plug-n-play, but it looks like those are different than the H11 bulbs (they lack the plastic housing and "elbow" part). Do you have to disassemble a stock bulb and use it with that?
Or if you have some installation pics or a DIY somewhere, that'd be awesome. Do you still need to push down the little "squirrel finders" so there's no glare to oncoming traffic?
Side by side cosmetic differences between BRZ and FRS/86 (same dimension lights) Moto-P FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 128 02-27-2019 07:25 PM
Side by side cosmetic differences between BRZ and FRS/86 (same dimension lights) Moto-P BRZ Photos, Videos, Wallpapers, Gallery Forum 109 08-19-2014 10:56 PM
Headlights too dim Franisco Other Vehicles & General Automotive Discussions 10 05-15-2012 04:11 PM
FR-S design differences jyoo Scion FR-S / Toyota 86 GT86 General Forum 36 09-20-2010 07:27 PM
