Old 08-10-2013, 07:32 PM   #1
86socal
86socal's Avatar
Drives: White frs
apexi n1 exv, stance super sport, st coiolovers
im deciding between these three apexi, stance or st coilovers. i havent seen a review for the apexi coilovers for our cars yet but i would like to know which one would you guys choose more for daily driving. thanks
86socal is offline   Reply With Quote
Old 08-11-2013, 08:24 AM   #2
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
ST. It's the cheapest out of those three. Only height adjustable, not dampening adjustable like the other two. Not sure if you're looking for DD only but ST is a great choice. Definitely what I'm going with.
Enraged21 is offline   Reply With Quote
Old 08-11-2013, 08:41 AM   #3
mrk1
Drives: Sterling BRZ Ltd
ST is really a great coilover for the money
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 08-11-2013, 02:58 PM   #4
console_cowboy
console_cowboy's Avatar
Drives: 2013 Black BRZ Limited
Well the ST coilovers are basically KW (very good quality coils) coilovers without the stainless steel body. I've heard good things about the coating ST uses and there are several good reviews on this forum. The ST coilovers may only have height adjustments, but I imagine they would perform the best. I would also check out RCE Tarmac coilovers as well if your budget is a bit higher.
console_cowboy is offline   Reply With Quote
Old 08-11-2013, 05:10 PM   #5
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
I have review on the St Coils on here. I am very satisfied with the coils thus far, if you plan on using them for using for DD then you can't beat the price of under 900. If you plan on adding camber plates then save your money and go with a full dampening coil system like Fortune 500, Tein Flex or Stance and of course KW3s.
Ny Brz is offline   Reply With Quote
Old 08-11-2013, 06:05 PM   #6
mike the snake
I'm really liking my ST coilovers a lot. Especially the spring rates, which are close to stock, so the ride doesn't suffer.
I researched, and I cannot figure out how the different companies are coming up with their spring rate decisions. I see rates from 4K to 10K, stiffer in front, some stiffer in the rear, at least the ST coilovers mimic the stock rates and retain the stock characteristics, with slightly softer rates in front if I'm not mistaken.
Old 08-11-2013, 07:21 PM   #7
Ny Brz
Hella Flush
Ny Brz's Avatar
The STs were meant for a entry/DD application that's why keep the SR close to stock feel. Other companies which have higher spring rates make those coils intended for use of race and track, if i decide to go full race or road race often i will end switching to KW3s.
Old 08-11-2013, 08:05 PM   #8
86socal
86socal's Avatar
Drives: White frs
Thanks for everyones input, i really appreciate it. i would really like to hear what others have to say on the other 2 coilovers, apexi and stance for ride quality
Old 08-13-2013, 06:19 PM   #9
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
For daily driving being the focus, ST for sure.
TylerLieberman is offline   Reply With Quote
The Following User Says Thank You to TylerLieberman For This Useful Post:
86socal (08-13-2013)
Stance Super Sport Coilovers FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-28-2015 08:59 PM
Concerns regarding Stance Super Sport coilovers brianlo622 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 07-12-2013 05:34 PM
Which coilovers? BC Racing or Stance Super Sport? Norcalmav23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 07-08-2013 04:40 PM
Lutz Performance | STANCE (Super Sport & Supe Sport+) coilovers Diego@lutzperformance Brakes, Suspension, Chassis 1 10-04-2012 01:43 PM
