Drives: White frs
apexi n1 exv, stance super sport, st coiolovers
im deciding between these three apexi, stance or st coilovers. i havent seen a review for the apexi coilovers for our cars yet but i would like to know which one would you guys choose more for daily driving. thanks
#2 |
#RememberTheBuster
Drives: Firestorm FRS MT
ST. It's the cheapest out of those three. Only height adjustable, not dampening adjustable like the other two. Not sure if you're looking for DD only but ST is a great choice. Definitely what I'm going with.
#3 |
Drives: Sterling BRZ Ltd
ST is really a great coilover for the money
#4 |
Drives: 2013 Black BRZ Limited
Well the ST coilovers are basically KW (very good quality coils) coilovers without the stainless steel body. I've heard good things about the coating ST uses and there are several good reviews on this forum. The ST coilovers may only have height adjustments, but I imagine they would perform the best. I would also check out RCE Tarmac coilovers as well if your budget is a bit higher.
#5 |
Hella Flush
Drives: 2013 SWP BRZ
I have review on the St Coils on here. I am very satisfied with the coils thus far, if you plan on using them for using for DD then you can't beat the price of under 900. If you plan on adding camber plates then save your money and go with a full dampening coil system like Fortune 500, Tein Flex or Stance and of course KW3s.
#6 |
I'm really liking my ST coilovers a lot. Especially the spring rates, which are close to stock, so the ride doesn't suffer.
I researched, and I cannot figure out how the different companies are coming up with their spring rate decisions. I see rates from 4K to 10K, stiffer in front, some stiffer in the rear, at least the ST coilovers mimic the stock rates and retain the stock characteristics, with slightly softer rates in front if I'm not mistaken. |
#7 | |
Hella Flush
#8 |
Drives: White frs
Thanks for everyones input, i really appreciate it. i would really like to hear what others have to say on the other 2 coilovers, apexi and stance for ride quality
#9 |
Drives: '24 GR86
For daily driving being the focus, ST for sure.
| The Following User Says Thank You to TylerLieberman For This Useful Post: | 86socal (08-13-2013) |
| Stance Super Sport Coilovers | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 06-28-2015 08:59 PM |
| Concerns regarding Stance Super Sport coilovers | brianlo622 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 07-12-2013 05:34 PM |
| Which coilovers? BC Racing or Stance Super Sport? | Norcalmav23 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 24 | 07-08-2013 04:40 PM |
| Lutz Performance | STANCE (Super Sport & Supe Sport+) coilovers | Diego@lutzperformance | Brakes, Suspension, Chassis | 1 | 10-04-2012 01:43 PM |
