Old 08-04-2013, 04:10 AM   #1
Hawk77FT
Drives: GTS 86
ABS and slippery road lights on - help
Ok, so I had an overpipe and front pipe installed and I had to take the steering rack off as it was in the way (rhd car). Everything went ok but now I have the abs and "slippery road" lights on. I have checked the fuses but not sure if it is right one.
Does anyone have any advice?
Sent from my HTC One X using Tapatalk 2
Hawk77FT is offline   Reply With Quote
Old 08-04-2013, 04:16 AM   #2
SigmaHyperion
Drives: 2013 SWP BRZ Limited
In most vehicles I've owned, having the ABS/ESC lights on is usually indicative of a sensor either malfunctioning or, more often than not, not being plugged in.
So I'd go back and check to see if you either unplugged an ABS sensor that you forgot to plug back in, or that somehow in the process of removing the rack one didn't actually get unplugged or damaged.
SigmaHyperion is offline   Reply With Quote
Old 08-04-2013, 04:27 AM   #3
Hawk77FT
Drives: GTS 86
Oh ok. Where the abs sensors would be on this car, you know.
Old 08-04-2013, 04:48 AM   #4
SigmaHyperion
And Step #4 of the process below shows 3 pictures related to the ABS sensor wire:
http://www.techautohow.org/2013/06/0...rs-subaru-brz/
The Following User Says Thank You to SigmaHyperion For This Useful Post:
Hawk77FT (08-04-2013)
Old 08-06-2013, 02:38 AM   #5
Hawk77FT
Drives: GTS 86
I have checked the wires, i even had my mechanic to check the wires but the light is still there. I had Toyota checking the system and it seems that the codes are still there. That makes me think:
1. are there any steering rack sensors? And if there are, where are they located? maybe the guy has knocked it off, or nicked the wires or something.
2. The steering rack has been taken off as well as the pinion input shaft so that might've caused the issue.
Any advice?
Old 08-06-2013, 10:55 PM   #6
Turdinator
Señor Member
Turdinator's Avatar
Any advice?
What codes is the car throwing? It may give us a hint of where to look next?
1974 TA22 Celica
2013 86 GT
Old 08-06-2013, 11:07 PM   #7
OrbitalEllipses
Drives: Attitude
Any advice?
The VSC brain is tied into the steering shaft at the clock spring (steering input sensor?) behind the steering wheel.
What are some good slippery narrow tires? PowderfaceTr. Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 02-07-2015 12:14 AM
LED "Off road" lights Trashed675 Cosmetic Modification (Interior/Exterior/Lighting) 39 06-18-2014 02:43 PM
Dunlop Direzza slippery when cold CHOPPER Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 10-18-2012 04:26 PM
2000 mile review, road trip to Road Atlanta & a chat with Randy Pobst. Mtechnik BRZ First-Gen (2012+) — General Topics 0 08-03-2012 11:07 AM
D1 Grand Prix Round 1 Photos from Odaiba - Slippery When Wet shawrf1 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 24 04-26-2012 01:39 AM
