Old 04-01-2013, 09:18 PM   #1
Snozzberries
Drives: FR-S Whiteout
Spacers and Strengthening
How large of spacers would you all go on your FR-S before strengthening. I haven't seen much talk about it yet.
I am considering 18" x 12" wheels with about 40mm - 60mm of spacer and a decent amount of track time on this setup. Normally I don't like spacers, but I will need them for a different bolt pattern.
Cheers!
Snozzberries is offline   Reply With Quote
Old 04-01-2013, 09:20 PM   #2
PRORICAN
PRORICAN's Avatar
April fools?
PRORICAN is offline   Reply With Quote
The Following User Says Thank You to PRORICAN For This Useful Post:
Jesse (04-01-2013)
Old 04-01-2013, 09:23 PM   #3
Snozzberries
Originally Posted by PRORICAN View Post
April fools?
No, I am actually curious if people have run into issues with large wheel setups.
Old 04-01-2013, 09:26 PM   #4
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
18x12 and track dont mix. also, 40-60mm spacers are huge.
Jesse is offline   Reply With Quote
Old 04-01-2013, 09:27 PM   #5
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
the answer is, find the right size and offset or go WBK
86_ZN6 is offline   Reply With Quote
Old 04-01-2013, 09:28 PM   #6
PRORICAN
PRORICAN's Avatar
Nope, still not falling for it!
Old 04-01-2013, 11:06 PM   #7
Snozzberries
So what size you max out at 17x10 with 10mm spacer?
Old 04-01-2013, 11:07 PM   #8
Snozzberries
WBK?
Can you provide some scope to "the right size" too please.
Old 04-02-2013, 02:56 AM   #9
eckoflyte
Drives: Toyota 86 GTS
what size tires you planning on fitting those 18x12 wheels? lol
eckoflyte is offline   Reply With Quote
Old 04-02-2013, 10:04 AM   #10
Vonsamhain
Vonsamhain's Avatar
Drives: Scion FR-S (Raven)
Has to be April Fools. Its do far out of the realm of possible that it has to be.
2013 Raven FR-S MT + Sparco Assetto 18x8 + Michelinn Pilot Super Sprot 225/40/r18 + Takeda CAI + Fortune Auto 500 coilovers + Tanabe Sustec front and Rear strut tower brace + Carbeau FX1 / 6 point harness / Harness Bar + Nameless front pipe + Perrin cat back + FA20club E85 tune + Wilwood front & rear brakes
Vonsamhain is offline   Reply With Quote
Old 04-02-2013, 10:48 AM   #11
Snozzberries
275/35r18 would be my guess without looking into it too much.
Old 04-02-2013, 10:57 AM   #12
Snozzberries
They make 18x12 wheels, they make tires that fit, seems to be possible. I didn't ask if it was a smart idea, I know there would be issues. I asked if it would break things.
Old 04-02-2013, 11:42 AM   #13
camelflage
Drives: pinto power
yes. 2-3" of spacer would put an interesting amount of stress on the hub/studs. might last a while, might last a day. if you do it, take pictures.
camelflage is offline   Reply With Quote
Eibach 20mm spacers just put on! SMOKETREES Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 12-18-2013 10:13 AM
5mm spacers and hub rings. zooki Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 04-05-2013 10:57 PM
Will WRX (GD) top hat spacers work on the BRZ? chim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 02-12-2013 08:56 PM
30 mm spacers possible? Maps316 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-08-2013 04:14 AM
H&R Wheel Spacers! vividracing Wheels and Tires 3 06-19-2012 05:11 PM
