Old 08-01-2013, 10:06 PM   #1
Frs32907
Drives: Asphalt grey, manual Fr-S
Opinion of perrin exhaust and aem intake?
Im think of doing a aem intake and perrin non res cat back catted front and also the over pipe. I will do header later on but do i need to tune before i get the header? Really just looking for a nice sound to start and then add header for some power. Hoping a tune isnt required at first for this setup
Frs32907 is offline   Reply With Quote
Old 08-01-2013, 10:27 PM   #2
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
No you don't need a tune unless you get headers. I prefer the Nameless Performance exhausts over the Perrin, but the Perrin one is good too. They are both local to me so lots of cars around here have both. I have the Nameless setup. Check my build thread if you'd like.
stockysnail is offline   Reply With Quote
Old 08-01-2013, 10:55 PM   #3
djdnz
1337
Drives: 2013 BRZ WRB S/C
Skip the intake, they're a marketing gimmick. The stock airbox with a good filter is a much better use of money, plus you'll have more cash to spend elsewhere
djdnz is offline   Reply With Quote
Old 08-01-2013, 11:50 PM   #4
DaveH
Drives: Scion FRS White
I second that, I went with Blitz LM Panel Filter, DSport tests show that most restrictive part is the filter and that effectively the stock intake is already very well designed.
DaveH is offline   Reply With Quote
Old 08-01-2013, 11:52 PM   #5
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
Our K&N dyno test only yielded a slight gain on that intake, and I'm pretty sure that was because the hood was open.
Perrin exhaust is definitely not. A lot of them running around Houston. I know someone is probably saying there are a lot of every aftermarket exhaust running around Houston.
PhastekSport is offline   Reply With Quote
Old 08-02-2013, 11:15 AM   #6
rapidcars
rapidcars's Avatar
Drives: 2013 DGM BRZ Limited
I just got the Perrin Non-Resonated catback and it is currently my only mod. I love the sound. Nice and deep with no raspiness or drone. It's loud at startup and when you really get on it but is relatively quiet at idle and cruising speeds. Couldn't be happier.
rapidcars is offline   Reply With Quote
Old 08-02-2013, 11:53 AM   #7
PERRIN_Mladen
PERRIN_Mladen's Avatar
Drives: '11 535i
If you plan on adding a header down the line, I recommend going with the resonated setup vs the non resonated. As adding a header, instantly makes the car MUCH more vocal.
I recommend the non resonated setup mainly to customers that want a louder/deeper toned exhaust, but do not plan on adding a header.
If loud is what you are aiming for, I'd recommend looking into our 3" exhaust. It is by far my personal favorite in regards to tone/loudness.
PERRIN_Mladen is offline   Reply With Quote
The Following User Says Thank You to PERRIN_Mladen For This Useful Post:
ftc~brz (08-02-2013)
Old 08-02-2013, 11:59 AM   #8
ftc~brz
Done
Drives: WRB BRZ
^this...my set up was great before the headers. now with no cats it's very very loud. I don't mind it most of the time and my last tune mellowed it out a bit when cruising. WOT it's ridiculous though.
ftc~brz is offline   Reply With Quote
Old 08-02-2013, 02:21 PM   #9
tennisfreak
Drives: 2018 BMW M240i
I already have the non resonated but want a header too. Do you think it would be too loud if I left the stock catted frontpipe on there with a header? Or do you think I would need to get a high flow catted header to keep the noise tolerable?
Old 08-02-2013, 04:04 PM   #10
PERRIN_Mladen
Drives: '11 535i
You will for sure hear a sound difference the moment you add a header. I have not personally heard a car that has had a header on their vehicle with a stock front pipe, so hopefully someone chimes in with more insight.
I am going to assume that it is still going to be loud, and only gets louder with an after market front pipe.
Old 08-02-2013, 04:10 PM   #11
wrxgoose
WUB WUB
Drives: 2013 Firestorm
it does. I had ordered the over-pipe and front pipe when I ordered the rest of the exhaust, but due to some shipping snafu, I had to wait to get the OP and FP. unfortunately no vids with stock OP/FP, but I do have some vids with the Perrin headerback exhaust. linked them in my build thread. (the dragstrip vids are full 3" exhaust, and she sounds so sexy)
wrxgoose is offline   Reply With Quote
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 09:47 PM
Feeler: Perrin Intake daywheniwaschillin Engine, Exhaust, Bolt-Ons 19 05-05-2013 08:24 PM
which exhaust? you opinion? imravenit Engine, Exhaust, Transmission 28 04-18-2013 01:17 AM
perrin pulley perrin intake tube Area51 Engine, Exhaust, Bolt-Ons 4 04-05-2013 06:11 PM
Perrin cold air intake Tyson Engine, Exhaust, Transmission 5 02-15-2013 12:06 PM
