Old 08-01-2013, 04:34 PM   #1
Minovsky
Minovsky's Avatar
Drives: Fr-s 2013 white out
DCW Glowing center console plaque and footwell lights
Hi I have question about DIYing some leds in the car! I want to install some foot well lights along with the Glowing plaque from DCW.. Would i be able to have the foot well lights go on independently from the dome light (Phasetek dome light kit) if i used a fuse tap also? Would it work if it was something like [Fuse tap, ---> Driver side LED, ---> DCW Glowing center plaque-->Passenger side Led, ---> dome light kit (Phastek)]? Would you know what kind of fuse i need at the fuse box? Do you think that would work? Also if i were to buy extra wires what type of wires should i get?
Minovsky is offline   Reply With Quote
Old 08-21-2013, 09:27 PM   #2
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
Almost any wire can work. I'd probably go to Radio Shack.
You can add additional power sources by using diodes to make sure no circuit back flows power into another. Be very careful not to short out the dome light circuit. It's controlled by the body ECU from what I can tell.
PhastekSport is offline   Reply With Quote
DCW custom glowing center console accent doggy Cosmetic Modification (Interior/Exterior/Lighting) 95 09-17-2013 04:16 PM
My Custom CNC Center Console Plaque Figo Cosmetic Modification (Interior/Exterior/Lighting) 4 07-19-2013 12:02 AM
Center Console Plaque flash408 BRZ First-Gen (2012+) — General Topics 13 05-09-2013 09:13 AM
86 Center Console Plaque 86_ZN6 Cosmetic Modification (Interior/Exterior/Lighting) 51 11-26-2012 06:54 PM
