Old 08-01-2013, 12:00 AM   #1
Dispect
Newbie Car Enthusiast
Dispect's Avatar
Drives: Asphalt 6MT FR-S
Perrin catback need help URGENT
Need advice urgently-
I had my Perrin UNRESONATED catback installed and drove it for a few days. No problem at all. No rasp even at WOT, very loud.
Then I had an aftermarket catless FP (not Perrin) installed but figured it was way too raspy and loud for my taste so I took it off and put my stock one back on.
Been driving for about a week plus now and ever since I put the stock front pipe back on, its been so quiet. Even quieter than when I first installed it.
And it became REALLY raspy. After startup, it rasps a lot at around 4k up to redline. After revving it out for a bit the rasp goes away. It never had this problem before when I first got it.
Any advice?
Dispect is offline   Reply With Quote
Old 08-01-2013, 01:18 AM   #2
schlomo
Drives: mazda3, 370z
Are you sure it is quieter than it was before? Maybe it just seems that way coming from the catless FP.
Definitely check for an exhaust leak.
schlomo is offline   Reply With Quote
Old 08-01-2013, 01:42 AM   #3
Dispect
Dispect's Avatar
how would i know if theres a leak? and what kind of tests can i run?
Old 08-01-2013, 01:52 AM   #4
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
There are two ways you can do this
1) Drive the car for a couple days and check to see if carbon leaks(Black stuff).
or..
2) (In cold starts) Turn on the car, spray some water onto the connecting pipes and see if air bubbles leak.
LeeMaster is offline   Reply With Quote
Old 08-01-2013, 03:29 AM   #5
Dispect
Dispect's Avatar
or..
i dont understand the 2nd one. care to elaborate pls?
Old 08-01-2013, 03:53 AM   #6
LeeMaster
Red wine
Pour water into a spray bottle
turn on the car
While the exhaust is still cold, spray water into these and check for air bubble.
If you see bubbles or air pressure pushing the water out, that is a clear indication that you have a leak
DANGER: Do not spray while the exhaust is still hot, harmful vapor and smoke will come out due to high temperature.
Old 08-01-2013, 04:02 AM   #7
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Start your car and feel for hot air blowing..
Old 08-01-2013, 04:02 AM   #8
Dispect
Dispect's Avatar
turn on the car
got it. ill try it tmw! thnks!
Old 08-01-2013, 05:54 AM   #9
number1Tango
Drives: Silver FRS
maybe the exhaust broke in and mellowed out?
number1Tango is offline   Reply With Quote
Old 08-01-2013, 11:36 AM   #10
AkaJabari
Drives: Scion FR-S, Scion tC
My guess is you forgot to reinstall the doughnut gasket that gets tossed when installing the Perrin originally.
AkaJabari is offline   Reply With Quote
Old 08-01-2013, 11:43 AM   #11
Dispect
Dispect's Avatar
no way. been less than a month. and why is it starting to rasp then?
so many things dont make sense
what is that? i got it done at a shop.
Old 08-01-2013, 11:50 AM   #12
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
The original gasket is shaped like a doughnut. When you install the Perrin kit they give you a flat gasket and the old doughnut gasket is not used.
Old 08-01-2013, 01:23 PM   #13
jdubz13frs
jdubz13frs's Avatar
Drives: 2013 Scion FR-S 6MT
You definetely have an exhaust leak somewhere. Check your gaskets.
jdubz13frs is offline   Reply With Quote
Old 08-01-2013, 01:48 PM   #14
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
For sure check for leaks. If gaskets were re used, they may need to be replaced. The car will sound different when the car is cold, but should mellow out when it's warmed up. Even with the unresonated cat back, it isn't too loud with the factory front pipe installed.
PERRIN_Chris is offline   Reply With Quote
PERRIN Big 3" Catback DAN_BRZ Engine, Exhaust, Transmission 95 04-28-2014 06:19 PM
Perrin non-res catback + FP combo Dispect Engine, Exhaust, Transmission 6 08-07-2013 12:25 PM
Perrin Catback Admired Engine, Exhaust, Transmission 8 07-19-2013 08:08 AM
WTB: Perrin Catback system WRB_BRZ Engine, Exhaust, Bolt-Ons 0 05-09-2013 10:22 PM
anyone with Perrin Resonated Catback? Tylub Southern California 5 04-02-2013 07:55 PM
