Old 07-30-2013, 04:44 PM   #1
mrbbs
Drives: GT86
non-squaling tires
Hi,
I'm looking for non-squealing tires, can anyone advise what to take?
Michelin Primacy HP and Wanli S1063 are both not usable for me.
thanks!
kevin
mrbbs is offline   Reply With Quote
Old 07-30-2013, 04:51 PM   #2
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
stop driving like an ass
/thread
supramkivtt2jz is offline   Reply With Quote
The Following 3 Users Say Thank You to supramkivtt2jz For This Useful Post:
G_Ride (07-31-2013), infinite012 (07-31-2013), Laika (08-03-2013)
Old 07-30-2013, 04:54 PM   #3
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
All tires are going to squeal if you push them enough. That said, I've found that the really sticky tires are quieter until you push them WAY past their limits.
Old 07-30-2013, 04:56 PM   #4
leon78
leon78's Avatar
Drives: 13 Whiteout
Pee on your tires.
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
The Following User Says Thank You to leon78 For This Useful Post:
Old 07-30-2013, 04:58 PM   #5
djdnz
1337
Drives: 2013 BRZ WRB S/C
My old Hankooks never squealed. They were Hankook Ventus HRII, but I don't think they make them anymore. Maybe their newer ones are similar.
djdnz is offline   Reply With Quote
Old 07-30-2013, 05:08 PM   #6
OrbitalEllipses
Drives: Attitude
Use more clutch when you shift.
Old 07-30-2013, 05:08 PM   #7
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
If you rub vaseline all over them they won't squeal.
You'll have to re-apply every 10-15 mins.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
The Following User Says Thank You to f0rge For This Useful Post:
stefmiesterb (07-31-2013)
Old 07-30-2013, 05:11 PM   #8
Tromatic
Tromatic is offline   Reply With Quote
Old 07-30-2013, 06:49 PM   #9
FRyeS
Drives: 2013 FR-S Asphalt 6MT
I wonder if Barney rolls on Shabbos
FRyeS is offline   Reply With Quote
Old 07-31-2013, 09:36 AM   #10
mrbbs
Drives: GT86
thanks, I might inform me on these.
If tires shouldn't squeal I shouldn't drive a GT86
I have installed a Cusco shorter FD and now tires tend to squeal just too much.
Other question: does someone know what makes a tire squeal?
Old 07-31-2013, 09:59 AM   #11
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Exactly. Maybe take your own hint.
Tires squeal when they are slipping against the road surface.
For instance: 1) When the tires are spinning faster than the car is going. 2) When the tires are stopped but the car is still going forward. 3) When the car is traveling in a different direction than the wheels are pointing (a slide). 4) On some cars the caster on the front wheels will cause a slight squeal while making tight turns.
All tires will squeal when there is no more traction to be had. Squealing tires means you aren't getting the best performance out of your car. You need to drive it better.
Squealing tires isn't something to be proud of if you're interested in driving well.
Grimlock is offline   Reply With Quote
Old 07-31-2013, 12:12 PM   #12
KONVERTER
KONVERTER's Avatar
It depends on the rubber.
If you have a softer compound you will have less squeal... Race rubber or a high performance summer tire will not squeal like the stock rubber.
The stock rubber is hard, will last longer, is better in wet and cold, and will chirp chirp chirp a lot.
KONVERTER is offline   Reply With Quote
Old 07-31-2013, 01:42 PM   #13
Hi,
thanks!
kevin
Bridgestone RE-11A. If that still makes too much noise, Hankook RS3. If STILL too much, Nitto NT01.
I don't recommend any in the rain except the RE-11A, and even that, only light rain.
Old 07-31-2013, 03:48 PM   #14
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
I owned a 2006 c6 z51 corvette for two years, those OEM tires have never squealed ever, even with traction is fully turned off, and they have a great grip.
adprokid is offline   Reply With Quote
Expensive light Rims+Expensive light Tires or Suspension+Cheaper Rims+Cheaper Tires? OnionTou Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 08-09-2013 06:57 PM
TIRES, TIRES, TIRES! @ Pure Automotive Performance Pure Automotive Wheels and Tires 1 02-04-2013 02:32 PM
Hate the Tires I got with my winter tires PoRco Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 12-31-2012 11:49 PM
FS: Gramlights 57d 17x9 +38 5x114.3 w/ tires 1500 miles on tires, $1800 shipped apexsti46 Wheels and Tires 6 09-05-2012 02:54 AM
