Old 07-29-2013, 10:59 PM   #1
diss7
Drives: AE86, 2x GT86, TE27
OEM Brake differences between different models
Just putting some info out there, as when I looked I couldn't find any.
In NZ, Japan, Australia, there were base models offered, these had smaller wheels, and also smaller brakes.
The differences are....
The front caliper and pads are the same between the models. However, the discs are different, the base has smaller discs. Also, because of the smaller disc, the caliper bracket is different.
The rear brakes on the base are entirely different. Different disc, caliper and pad.
So, if you have a base model, and are looking for new pads, you can get the same pads for the front as the higher spec model, but you will need base 86 specific rear pads. The TRD part number for these base 86 specific rear pads is MS226-18002
diss7 is offline   Reply With Quote
The Following User Says Thank You to diss7 For This Useful Post:
feldy (07-31-2013)
Old 07-30-2013, 08:05 AM   #2
wparsons
wparsons's Avatar
The rears on the lower spec cars also runs a solid disc instead of the vented discs that everyone else gets.
flickr
Old 07-30-2013, 08:16 AM   #3
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Rear pads on base are WRX aren't they? IIRC specs were the same, I never bothered to verify 100% though since all were high spec brakes on this side of the pond.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-30-2013, 09:14 AM   #4
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Yup, all USDM cars get the same brakes which are the up-model brakes from the overseas cars. The fronts are from the current WRX, and the rears are from the current Legacy GT/3.6R.
Old 07-30-2013, 08:10 PM   #5
wparsons
wparsons's Avatar
Close, IIRC the low spec solid discs are from the base impreza, not WRX. I also believe the low spec fronts are impreza parts too.
flickr
BRZ/FRS big brake kit vs WRX counterparts: brake piston size (differences, if any)? mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-25-2013 12:07 PM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-24-2013 11:26 PM
Brake rotor differences between base and Sport-tech BRZ Sport-Tech CANADA 10 04-12-2013 07:15 AM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
CDN vs US FR-S differences Sport-Tech CANADA 77 04-19-2012 02:24 PM
