Drives: red frs
Nissan z to frs brake upgrades?
I found this and i dont speak or read japanese...
anyone shed some more light on this? Is it lighter? better balanced? z brakes are easy to come by. http://www.global-z.com/ |
Drives: Attitude
Basically the same thing as Subaru 4-pot brakes, heavily discussed on NASIOC.
Drives: red frs
Drives: Attitude
Turbo Z32 should have had aluminum 4 pots up front; I believe in certain discussions caliper flex has come up and there are those who contend the iron calipers are "better" due their rigidity. There may still be someone aside from Global-Z that makes brackets to adapt to Subaru uprights, but it's not exactly popular as the Subaru 4 pots bolt right up and aren't *that* difficult to find. If you're looking to save a few bucks and can paint them yourself, remans are readily available.
#5 | |
Drives: 2005 Toyota Camry
http://importnut.net/300zxbrakeswap.htm (my friend Asad compiled this info, but for the site itself) As for caliper flex, for a car our weight (2700lbs) it's not an issue. I had problems before with my setup on my S13, and it was due to a slightly bad wheel bearing. -alex |
Drives: Attitude
Good info, thanks!
blowhard
Drives: frs, project forester
Actually had put together a set for this a couple years back, then found a deal on new brembo calipers.
Have brackets ( from a seller making them on forester forums) that will let me use lgt front rotors, tempted to put on the frs. Right now are just collecting dust. Don't think the rears can be used without a different bracket though since these cars take the newer Subaru rear brake style. |
#8 | |
What does vehicle weight have to do with caliper flex? The caliper isn't supporting any weight, and a lower vehicle weight won't stop you from pushing as hard on the pedal... Lower grip tires I could understand since the ABS will reduce fluid pressure to the caliper to keep the tires from locking, but you'll need more fluid pressure (and flex potential) to stop a LIGHT car on sticky tires than a heavy car on average tires.
#9 | |
^^^ "flex" in the sense that the calipers cannot handle the load(s) of the car under braking as well, and the caliper halves "flex"...
I've rebuilt several sets of Z32 calipers before, and the entire assembly is held together with 4 pins. The caliper themselves are prone to heatsoak, and on the Z32 chassis the aluminum calipers seem to not do as well under repeated braking versus the iron counterparts. A sequence could look like this: Quote:
What it comes down to is this: for purposes of using Z32 brakes on our cars, it works fine with the proper adapter hats and drilled rotors. -alex |
| Project Mu, Stop Tech, Endless + more Brake Upgrades! | Speed Element | Brakes, Suspension, Chassis | 390 | 10-11-2015 10:48 AM |
| Brake Upgrades by 86Drift | 86drift | Australia Classifieds | 40 | 04-25-2013 08:16 AM |
| StopTech Introduces Sport Kit Brake Upgrades!! | vividracing | Brakes, Suspension, Chassis | 0 | 06-27-2012 02:41 PM |
