Old 06-10-2013, 03:42 PM   #1
PumaSTi
Drives: 2013 BRZ Limited. 2016 Forester XT
BRZ backup camera issues
Alright hopefully someone can chime in and help with this
I installed a Kenwood c-mos 200 on the BRZ, the camera was previously installed in my 2011 STi with no issues, I purchased the beat-sonic adapter and wired everything how it should be.
The issue I'm having is the radio not switching to the camera when I put it in reverse, but it works when I'm in the diagnostic menu as it should, put it on reverse and I can see the camera and the lines, but not when the radio is on any other screen.
Any help is greatly appreciated.
PumaSTi is offline   Reply With Quote
Old 06-10-2013, 04:20 PM   #2
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
I got nothin for you brother. Maybe try @SVXdc? He's crazy helpful and very in touch with these issues.
Beyer Subaru is offline   Reply With Quote
Old 06-12-2013, 11:10 AM   #3
console_cowboy
console_cowboy's Avatar
Drives: 2013 Black BRZ Limited
How did you wire up the power to your backup camera? You need to make sure that it is powered from the headunit itself or from a constant power source. The camera has to be powered on when the head unit first turns on. If it is not, it will not be detected as an option and the factory head unit will not switch to the camera when you go into reverse. If you're powered off the reverse lights, then you would see the reverse camera come on in the diagnostics when you put the car in reverse.
console_cowboy is offline   Reply With Quote
DIY Backup camera for BeSpoke and 2014 Pioneer post_break DIY (Do-It-Yourself) Guides 48 06-01-2017 12:57 PM
Scion FRS Bespoke Backup Camera, What do I need? post_break Electronics | Audio | NAV | Infotainment 8 07-02-2016 09:55 PM
Kenwood CMOS-210 Backup Camera Install TSY Electronics | Audio | NAV | Infotainment 34 12-10-2014 01:18 PM
Running Backup Camera Wire Tony Mac Electronics | Audio | NAV | Infotainment 9 12-04-2013 11:28 PM
Backup Camera Help husker741 Electronics | Audio | NAV | Infotainment 2 02-13-2013 01:04 AM
