Drives: FR-S & BRZ
SPL Pro Suspension
We are proud to be carrying SPL Parts once again for the FR-S and BRZ guys!
Coming from the Nissan community we have installed countless amounts of SPL parts for the 240sx, 350z, and 370z cars out there! These parts have been tested on track and street with great success. SPL Parts' quality is unmatched in the aftermarket suspension arms world as they use top quality FK/QA1 bearings and rod ends and CNC machined aluminum, Chromoly and Titanium for their securing locks. ![]() Our sponsored time attack car has the full SPL parts line on it! ![]() ![]() ![]() Here are some pictures of the rear arms for the FR-S and BRZ! ![]() ![]() We'll be stocking the Rear Lateral Links! ![]() ![]() ![]() Full SPL Line on the subframe of an FRS! ![]() ![]() ![]()
| The Following User Says Thank You to Corner3garage For This Useful Post: | TylerLieberman (07-23-2013) |
Drives: 2013 Scion FR-S, 1993 Lexus SC300
SPL is quality. I have used a ton of their 240SX stuff. I saw they had added an FR-S/BRZ section to their site a couple months ago. Excited that the stuff is now out.
| The Following User Says Thank You to FrX For This Useful Post: | Corner3garage (07-24-2013) |
Drives: FR-S & BRZ
![]() Finally in stock for your alignment needs! |
Just a dude
Drives: Scion FR-S 2013
With these LCAs would one worry about NVH or a non issue?
| The Following 2 Users Say Thank You to OICU812 For This Useful Post: | Corner3garage (07-26-2013), Vic4uf (06-06-2016) |
Drives: FR-S & BRZ
They are definitely going to be much more solid feel than a rubber bushing arm with no heim joints, but most of the cars we have installed SPL arms on do not have THAT much of a noise issue as the Knuckles have a rubber bushing as well as the subframe. |
| The Following User Says Thank You to Corner3garage For This Useful Post: | OICU812 (09-30-2013) |
Drives: Scion FR-S
Any rear upper control arms?
Drives: Toyota 86 GTS
this stuff looks the goods.
Drives: BMW E84
Oh crap. I'm selling my Cusco stuffs.
| The Following User Says Thank You to B L U E S L A T E For This Useful Post: | Corner3garage (07-30-2013) |
Drives: FR-S & BRZ
#10 |
Drives: 2003 Subaru Outback
Do adjustable control arms and the whiteline camber kit work well together to adjust camber? I want to make sure when lowering the car and putting new wheels on I can run as little camber as possible.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
#11 | |
Drives: FR-S & BRZ
The alignment usually gets to ~.1 to .5 degree negative camber in the front and ~2.5 to 3 degrees negative camber on the rears, when lowering the car on springs without alignment. -Mike |
#12 | |
#13 |
Does anyone run into the axles popping out of the CV joints when running longer lower control arms?
#14 |
Drives: FR-S & BRZ
| MCA Suspension. Anyone have them on their 86? | Walldodger | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 89 | 09-11-2013 11:30 PM |
| Suspension available @ TIC | Turn in Concepts | Brakes, Suspension, Chassis | 5 | 08-06-2013 11:10 AM |
| FS: OEM BRZ Suspension | midnight23 | Brakes, Suspension, Chassis | 10 | 07-24-2013 07:47 AM |
| fs suspension | DanoFA20 | Brakes, Suspension, Chassis | 0 | 06-27-2013 09:02 AM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
