Old 07-23-2013, 02:09 AM   #1
Bmore_Raven86
Drives: Scion FRS Raven
I have a 18x7.5+38 wheels..How wide can i go with tires
Need your help guys..
Bmore_Raven86 is offline   Reply With Quote
Old 07-23-2013, 11:51 AM   #2
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
You could probably rock a 245, but for optimal performance, I wouldn't run anything other than a 225/40-18.
enjoyminutemaid is offline   Reply With Quote
Old 07-23-2013, 12:04 PM   #3
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Yeah, I have 18x7.5 +48 and chose to go with 225/40/18. You can go with tires as wide as 245/255 but I still wanted a square setup so I can rotate as necessary and reduce understeer some say may come with a staggered setup (although I'm pretty sure you won't really feel a slight stagger). But really one of the main reasons I went with 225/40/18 is because there are a lot of tires made in this size and you have many options from many different tire manufacturers at really good prices - I recently picked up some Goodyear Eagle F1 Asymmetric 2 summer tires for $90/ea after rebate.
As an aside point unrelated to tire width, you can also go with lower profile 35 tires; 40's will be ~12mm larger than stock and 35's will be ~11mm smaller than stock, your choice. Ride quality will suffer some with 35s (not to mention potholes have a higher chance of doing some damage). Both the 40 and 35 are well within the 3% within stock rule of thumb. But again, wider lower profile tires will be more expensive.
mit_peid is offline   Reply With Quote
Wheel Directory: TRD SF2 18x7.5 +46 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 07-22-2016 08:22 PM
How wide and aggressive on stock tires? euroshowoff Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 04-19-2013 06:40 PM
why are aftermarket wheels so wide? VoiD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 03-20-2013 11:07 AM
235 mm tires, great fit but not too wide Black Tire Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 02-07-2013 08:38 AM
For those guys with wide wheels jkonquer Off-Topic Lounge [WARNING: NO POLITICS] 1 11-02-2012 02:18 PM
