Old 07-21-2013, 11:36 PM   #1
256brz2013
Drives: 2013 white brz
brz subwoofer install
Well i installed a sub/amp in my brz. Used a line out connection to connect the rc inputs to the amp. Long story short the sub works/amp powers on. But it doesnt beat near as hard as it should. I tuned the amp to where it should be. And it still isnt beating real hard. What am i missing?
256brz2013 is offline   Reply With Quote
Old 07-21-2013, 11:38 PM   #2
mashal
DADA
mashal's Avatar
Drives: 2013
Stock HU? If so its only a 2.4v pre out. Get a loc and it will be banging then
mashal is offline   Reply With Quote
Old 07-21-2013, 11:43 PM   #3
256brz2013
Stock deck. Idk all the lingo. Whats a loc??
Old 07-22-2013, 12:13 AM   #4
mashal
DADA
mashal's Avatar
Drives: 2013
Line output converter. On your amp you should have a voltage in setting. Make sure that is on the low setting , should make it a tad better with proper gain settings
Old 07-22-2013, 12:29 AM   #5
256brz2013
i have a line out converter hooked up. Thats how i ran the amp to the radio. The sub
Old 07-22-2013, 01:27 AM   #6
Sbeezy
Drives: 2001 ZX2, WRBP BRZ (soon hopefully)
does the amp have a switch for line output voltage that says 1-2v or 4-6 v if so put it on 1-2v also what amp is it?
Sbeezy is offline   Reply With Quote
Old 07-22-2013, 01:35 AM   #7
256brz2013
i'll check on that tomorrow and let you know the model of the amp.
Old 07-22-2013, 01:39 AM   #8
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
line out converter is your issue need higher voltage line out converter
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 07-22-2013, 01:44 AM   #9
Sbeezy
put a line driver in between the amp and LOC if your amp doesn't have the sensitivity switch by the gains. or if the LOC has Pots turn them up about 75% of the way and then turn the deck up 75% and set those gains to the max unclipped level
Old 07-22-2013, 09:23 AM   #10
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
Where did you put your LOC? Don't use the rear speakers - they have a high pass filter on them from the head unit. You need to get the signal from the front speakers (these wires are at the amp in the trunk).
rmjjensen is offline   Reply With Quote
Old 07-22-2013, 01:03 PM   #11
256brz2013
i used vampire clips to run the lineout threw the front speakers
Subwoofer now available Opie Electronics | Audio | NAV | Infotainment 97 08-15-2015 08:23 PM
3 Way Active without a Subwoofer stea1thbear Electronics | Audio | NAV | Infotainment 42 10-14-2013 02:03 AM
Subwoofer/Amp install problem evanmd Electronics | Audio | NAV | Infotainment 4 07-22-2013 03:50 AM
Subwoofer? yomchi1989 AUSTRALIA 31 09-06-2012 09:23 PM
Does BRZ and FRS come with a Subwoofer? R0ME0 FR-S / BRZ vs.... 6 05-07-2012 02:54 PM
