Old 07-19-2013, 11:23 PM   #1
Dispect
Newbie Car Enthusiast
Dispect's Avatar
Drives: Asphalt 6MT FR-S
raspy note
hey guys,
i just recently got my exhaust work done.
perrin non-res catback
paired with a t1r catless front pipe.
i noticed a bit of raspyness after adding the front pipe. any way i can resolve this?
Dispect is offline   Reply With Quote
Old 07-19-2013, 11:33 PM   #2
brzadmir
Drives: 13' BRZ, 05' 325xi, 02' RAV4
Catted front pipe
Originally Posted by Dispect View Post
hey guys,
brzadmir is offline   Reply With Quote
Old 07-19-2013, 11:36 PM   #3
Wo6M
Keep Calm And Drift On~
Wo6M's Avatar
Drives: Scion FR-S WhiteOut 6 Speed Manual
You could check for a exhaust leak. In most cases IMO are exhaust parts not lined up correctly allowing bits of exhaust to blow by causing this sound.
I do suggest posting a video so the community can further assist you.
2013 Scion FR-S White Out Six Speed Manual
Mods:
Wo6M is offline   Reply With Quote
Old 07-20-2013, 12:00 AM   #4
Dispect
Dispect's Avatar
will do that tomorrow as it is a little late and dark out. thank you!
Old 07-20-2013, 12:01 AM   #5
Dispect
Dispect's Avatar
Originally Posted by brzadmir View Post
Catted front pipe
t1r doesnt have any catted ones :/ will carbon build up help mellow it down a little? its not to the point where its unbearable but its there and i know its there and im kinda OCD
Old 07-20-2013, 12:02 AM   #6
Propaganda
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
You could add a resonator in there somewhere.
I put a header on my last 4-banger and it was too raspy for my liking. I added in a resonator on the midpipe and it helped out a bit (also killed some drone and made it a tad bit quieter)
Propaganda is offline   Reply With Quote
Old 07-20-2013, 12:19 AM   #7
Dispect
Dispect's Avatar
i thought about that. even got a quote from perrin for a resonated mid pipe. but as of right now, i really like the sound level. i think its perfect. only issue is the rasp.
Old 07-20-2013, 08:32 AM   #8
FR-S Matt
Get a small resonator or add the cat to the front pipe.
Old 07-20-2013, 08:41 AM   #9
Captain Insano
Resonators don't change the sound level that much (minimal) they mainly help eliminate drone and raspyness. Granted, it depends on which type of resonator as there are some different types to choose from.
I have two resonators on mine right now (catless resonated front pipe and resonated midpipe - both simple canister resonators).
Old 07-20-2013, 09:30 AM   #10
wparsons
wparsons's Avatar
You need either a catted front pipe, or a resonated mid pipe. An exhaust leak won't cause rasp, and carbon build up won't stop it.
flickr
Old 07-20-2013, 09:40 AM   #11
FastLane1000
FastLane1000's Avatar
Drives: White FR-S, 6M
You could also try header wrap on the front pipe.
FastLane1000 is offline   Reply With Quote
Old 07-20-2013, 11:04 AM   #12
Sing4LTS
Drives: 13' FR-S
What would the header wrap do?
Sing4LTS is offline   Reply With Quote
Old 07-20-2013, 11:09 AM   #13
FastLane1000
It helps to reduce and soak up vibrations that cause the raspiness. It helped eliminate rasp I got from my header instalation.
Old 07-20-2013, 05:56 PM   #14
wparsons
wparsons's Avatar
Rasp isn't from vibration.... and if the header wrap stops the pipes from vibrating they're WAY too flimsy.
The only way header wrap would stop a noise would be if the header or front pipe was rubbing on a heat shield or metal part of the car.
flickr
Raspy header and weird noise Scalzo Engine, Exhaust, Transmission 39 08-24-2020 07:40 PM
Name that exhaust note Rampage BRZ Photos, Videos, Wallpapers, Gallery Forum 1 04-14-2012 05:52 AM
