P i N O Y P R i D E
Drives: 86 C7P MT
Re-using tires thoughts
Im planning to reuse my current tires for fronts and buy a new larger tire for my rears, but the local tire shop in my area giving me a warning of dismounting and reuse for my new wheels, giving me warning for possibility of damaging of the sidewall, coz of the pressure of the metal spoon might cause to tear/puncture/bubble due to low profile sidewall tires.
any thoughts of possibility of damage?
BS. I'd go somewhere else.
Edit: I mean.. it's possible, but if anything happened to the sidewall it would be their fault and their problem.
| The Following 2 Users Say Thank You to qoncept For This Useful Post: | 86 FRS (07-16-2013), SkullWorks (07-16-2013) |
Custom User Title
Drives: Asphalt FR-S MT
Isn't the only difference between a new and a used tire the tread depth? There's a little coloration and a few heat cycles, but that shouldn't be anything to consider here.
Drives: 2008 Honda Civic Si
Go to a different shop. The only things I'd check for when getting used tires are these:
1. Check the manufacturer date of the tires. Tires have an expiration date so make sure the ones you get are not expired. 2. Check for any damage. Holes/bubbles/damage/etc. I wouldn't put on a tire that has side wall damage since that can't be repaired. 3. The wear of the tire. |
| Thoughts on Kumho Tires? | brillo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 06-05-2013 03:51 AM |
| TIRES, TIRES, TIRES! @ Pure Automotive Performance | Pure Automotive | Wheels and Tires | 1 | 02-04-2013 02:32 PM |
| Thoughts on JVC? | joelg | Electronics | Audio | NAV | Infotainment | 14 | 01-02-2013 05:56 AM |
| FS: Gramlights 57d 17x9 +38 5x114.3 w/ tires 1500 miles on tires, $1800 shipped | apexsti46 | Wheels and Tires | 6 | 09-05-2012 02:54 AM |
