Old 07-16-2013, 04:08 PM   #1
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Oil cooler with filter relocation, thoughts?
So I've been looking at the mocal kit that @F1point4 put together as well as the Mishimoto and I found this one.
http://www.godspeedproject.com/Oil-C...relocation-kit
It is similar to the Griffon kit where the lines point upwards only this relocates the filter.
So the idea is this...
Line from the oil filter thread, to the oil filter, from the oil filter to the radiator, from the radiator to the oil filter thread.
This would let you locate the oil filter lower in the engine bay, say around the ABS, stick the radiator in the drivers side fender area (removing or getting a smaller washer fluid tank), and give you the room needed to change air filters.
What are your thoughts on this kit? There is no thermostat so get a radiator sweater for the winter.
As a bonus you can attach an oil pressure and oil temp probe to the filter.
post_break is offline   Reply With Quote
The Following User Says Thank You to post_break For This Useful Post:
86_Insider (07-16-2013)
Old 07-16-2013, 04:30 PM   #2
leon78
leon78's Avatar
Drives: 13 Whiteout
Subbed for R&D on a twin’s application. For the price point...it may be a good set-up if not alot of investment is needed.
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 07-16-2013, 05:17 PM   #3
Ross
Drives: 85 corolla gts
I did a remote mount filter on one, as well added a very large cooler. total system requires roughly 8 quarts of oil to fill from empty. The only reason we did this was do to spacing by the turbo. If it is an option I would recommend trying to keep the filter were it is for keeping servicing easy. Also please keep in mind the quality of the products you are using. Godspeed may be a some what well know brand, but it is well known for typically selling very cheap stuff mad in China. Also keep in mind this is your oiling system and the last thing I would use a cheap product on is that, it is the blood of your engine so to speak. Mocal, Griffin, Setrab on the other hand is a very good products.
Ross is offline   Reply With Quote
Old 07-16-2013, 05:32 PM   #4
post_break
post_break's Avatar
The Godspeed kit is very low quality and the more I look at it the more I like the Mocal kit. I just think the oil cooler have serious clearance issues, even the ones designed for our cars.
We need something like this:
The tap is on the top, not the side. I'm still researching stuff to find something that isn't such a tight squeeze.
Old 07-16-2013, 05:33 PM   #5
Hanakuso
Why can't you just use a banjo bolt with the mocal kit?
Hanakuso is offline   Reply With Quote
Old 07-16-2013, 05:35 PM   #6
post_break
post_break's Avatar
You can probably just use a 90 degree or 45 degree angled connector, like pictured, I was just trying to source other options.
http://www.racerpartswholesale.com/p...able_Fittings2
cooler, oil
Thoughts on eBay Oil Cooler kits? @Art_Mighty Engine, Exhaust, Transmission 15 04-10-2014 08:38 AM
Possible Relocation to Indianapolis 2_slo Off-Topic Lounge [WARNING: NO POLITICS] 5 05-31-2013 07:29 AM
Perrins new CAI vs Perrin drop in filter. Thoughts? NickFRS Engine, Exhaust, Transmission 76 01-22-2013 12:39 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
Badge Relocation danthedirt Cosmetic Modification (Interior/Exterior/Lighting) 11 06-15-2012 11:40 PM
