Old 07-16-2013, 05:32 AM   #1
eckoflyte
Drives: Toyota 86 GTS
Swaybar hitting control arm - adjustable links enough?
hey guys,
got around to fitting new coilovers and robispec control arms this weekend. Haven't taken the car off the stands yet as it seems I'll need a solution to this swaybar/control arm issue.
By the looks of it, I am not sure if the range on the adjustable links would be enough to clear the control arm. Most of the aftermarket links have about 20mm of adjustability to go longer (10mm) or shorter (10mm) than OEM, this is obviously a rough estimate. Will this be enough to fix this issue?
eckoflyte is offline   Reply With Quote
Old 07-16-2013, 10:54 AM   #2
qoncept
qoncept's Avatar
Yes. Some people have cut and shortened the stock endlinks. For a $200 savings I probably would have to if my sway bar didn't come with them.
qoncept is offline   Reply With Quote
Old 07-16-2013, 11:06 AM   #3
Slash
Slash's Avatar
Drives: 2013 FRS
Funny my "cheap" Isis coilovers came with them.
Sent from my SGH-T999 using Tapatalk 2
Slash is offline   Reply With Quote
Old 07-16-2013, 11:09 AM   #4
whataboutbob
AutoX-10/10ths every run
I am not so much interested in the endlinks, are those Ohlins on that car?
Build thread:Here
Old 07-16-2013, 11:13 AM   #5
qoncept
qoncept's Avatar
My "cheap" harbor freight angle grinder came with extra brushes.
Old 07-16-2013, 06:11 PM   #6
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
Shortening my endlinks was the only way to stop the contact between both my swaybar (StranoBar v2) and also the endlink bolts with the lower control arm. It was hitting on both sides (so I'm sure the bar was properly centered, lol).
I am using the Whiteline adjustable links, and they only seem to start out at stock length (I don't feel comfortable with the amount of threads engaged if made any longer) and go shorter from there.
neurokinetik is offline   Reply With Quote
Old 07-16-2013, 06:43 PM   #7
Calum
That Guy
Drives: 2013 asphalt FRS MT
I'm still shocked that @Racecomp Engineering or @robispec or @Sam Strano or @Whiteline or anyone one else I'm forgetting hasn't made a sway bar with straight arms. It would solve this issue and make the bar able to adjust.
Old 07-16-2013, 07:20 PM   #8
onefasazn
Drives: Chevrolegs
I know Whiteline has universal endlinks with differing length center sections. Just measure what length you need and give them a call.
onefasazn is offline   Reply With Quote
Old 07-16-2013, 08:07 PM   #9
qoncept
qoncept's Avatar
It's pretty tight in there. I think it might end up interfering with the wheel if it's not bent the way it is.
Old 07-16-2013, 08:38 PM   #10
simpleisbest
Senior Citizen
Drives: Scion FR-S
Can't you adjust those control arms for more clearance?
simpleisbest is offline   Reply With Quote
Old 07-16-2013, 08:43 PM   #11
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
Is this at full droop? Have you checked clearance with the car on the ground?
Sent from my Nexus 4 using Tapatalk 2
RiskyTrousers is offline   Reply With Quote
Old 07-16-2013, 08:45 PM   #12
RiskyTrousers
Nevermind, took a closer look at the pic.
Old 07-17-2013, 04:44 AM   #13
eckoflyte
Thanks. I had a look at the whiteline spec page for the end links and it seems like it starts out at stock length of 25cm, and is able to be shortened down to 20cm. 5cm should more than cover me. These are exact specs as shown here:
http://www.whiteline.com.au/product_..._number=KLC179
Old 07-17-2013, 04:46 AM   #14
eckoflyte
They are indeed Ohlins. Cant comment on how they feel or handle as I've yet to take the car off the stands and go get an alignment.
Password:JDM Ultimate Adjustable Sway Bar Links Subaru BRZ / Scion FR-S *Group Buy* password:jdm Groupbuys 119 01-28-2015 06:22 PM
Ground Control Complete Coilover Suspension Kit and Adjustable End Links Eric1855 Brakes, Suspension, Chassis 12 05-26-2013 12:02 AM
Ground Control Swaybar Endlinks GC_Adam Brakes, Suspension, Chassis 6 01-02-2013 01:08 PM
Setting adjustable sway bar links Im_SPEED Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 10-01-2012 09:12 PM
