Old 07-16-2013, 12:00 AM   #1
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
slammed + driveways = tc on
Anyone have issues with your slammed suspension or coilovers with reduced suspension travel? I have about 3.5" of clearance and have to go up diagonally on almost every driveway. on the very steep ones I end up 3 wheeling it and sets off the traction control all the time. The noise sounds pretty bad. Even if I turn off the tc once the wheel gets airborn the tc comes back on.
garfull is offline   Reply With Quote
Old 07-16-2013, 01:21 AM   #2
Turdinator
Señor Member
Turdinator's Avatar
That is the car applying the brakes to the wheel in the air so you can still drive forward. Without this the wheel in the air would just spin and you would go nowhere. The only ways i can see to remedy that is to remove the helical LSD and install a plated LSD in its place. Or you could swap your coilovers for some with more droop travel. Either way its not a cheap fix.
1974 TA22 Celica
2013 86 GT
Old 07-16-2013, 01:25 AM   #3
garfull
garfull's Avatar
i wonder other than stressing the unibody with this teeter todder everyday, how bad is this for the abs module.
im almost ready to pull the trigger and repave my driveway.
Old 07-16-2013, 09:26 PM   #4
d1ck
Drives: Black 2013 FRS
The abs module is just turning on the pump and operating some solenoids. Normal operation for an ABS system.
d1ck is offline   Reply With Quote
Old 07-16-2013, 09:42 PM   #5
mrk1
Drives: Sterling BRZ Ltd
Its certainly a stress on the chassis, long term damage? who's to say. I had a Mini that used to tripod a lot and I put 75k on that car like that with no problems.
I know off road guys will sometime drag the brakes slightly when a wheel comes off the ground. This is for trucks that have LSD's and not lockers, by doing this you slow that spinning wheel making the diff transfer torque to the wheel that still on the ground. ABS obviously doesn't like this and interfere but not be damaged.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 07-17-2013, 11:57 AM   #6
wparsons
wparsons's Avatar
If you do the "pedal dance" it won't engage TC, even with a wheel in the air... but like it's already been stated, all you'll do then is spin the wheel in the air and not go anywhere.
flickr
Old 07-17-2013, 04:47 PM   #7
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
I would just raise the car abit first? Lol
Old 07-17-2013, 05:01 PM   #8
OrbitalEllipses
Drives: Attitude
Engaging the parking brake a click or two should help get you moving...though that doesn't really seem to be an issue since the TC is working as intended.
Old 07-17-2013, 05:02 PM   #9
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
I lift the inside rear wheel every single time. Lowered with Eibach sway bars and also have lots of chassis/suspension bracing. Stiff chassis and suspension = dog legging on driveways.
If you get stuck just pull the e-brake up a notch or two and it'll get traction and go.
chadstyle is offline   Reply With Quote
Old 07-17-2013, 05:02 PM   #10
chadstyle
chadstyle's Avatar
Lol you beat me by 55 seconds
Old 07-17-2013, 06:38 PM   #11
garfull
garfull's Avatar
Parking brake...I'll try that.
Dog legging, that's one I've never heard of.
Old 07-17-2013, 06:41 PM   #12
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
My rear end is so stiff with the 22mm sway/links that I 3 wheel it coming out of my driveway. I'm only on h&r springs.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
Old 07-17-2013, 07:02 PM   #13
infinite012
Drives: 13 DGM BRZ Ltd
I will not upgrade my rear sway bars/get coilovers because of this exact issue. It was annoying in the STI and it'll be annoying in the BRZ.
infinite012 is offline   Reply With Quote
Old 07-17-2013, 08:37 PM   #14
chadstyle
chadstyle's Avatar
But the car handles like its on rails!! So worth it!!
nab335's Firestorm slammed on BC racing coils! nab335 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 45 05-09-2014 01:40 PM
Slammed Society 19 May Trixie_Lava Hawaii 4 05-19-2013 04:58 AM
When looking slammed, and being low is not good enough, we present you the Black-i… F Moto-P Scion FR-S / Toyota 86 GT86 General Forum 11 03-18-2013 02:15 PM
Slammed BRZ render featured on StanceNation Saibot BRZ Photos, Videos, Wallpapers, Gallery Forum 68 04-11-2012 01:55 AM
Slammed GT-86 Spotted at Thailand Autoshow Jayvelliott Scion FR-S / Toyota 86 GT86 General Forum 19 03-28-2012 06:09 PM
