Old 07-12-2013, 05:56 PM   #1
BlackyRose
Drives: 2013 Raven FR-S
Best Buy/Sonic Electronix/Crutchfield speaker replacement
All I want is direct plug and play speakers for the doors. A simple saturday afternoon take of the door panel type of day. Ive called a bunch of retailers and they give me excuses about the door speakers not having proper fitment.
Has anyone found a good over the counter direct plug and play door speaker for the two side doors. I am leaving the 4 speakers on the dash and the two rears in place. Just want a cheap simple upgrade for the doors as they have limited range and seem to struggle...
BlackyRose is offline   Reply With Quote
Old 07-12-2013, 06:53 PM   #2
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
[ame="http://www.amazon.com/Infinity-Reference-6032si-Performance-Loudspeaker/dp/B002C8AFEE"]Amazon.com: Infinity Reference 6032si 6.5-Inch, Shallow Mount High Performance 180-Watt Two-Way Loudspeaker (Pair): Car Electronics[/ame]
I have these.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
The Following User Says Thank You to Tim_Asphalt_FRS For This Useful Post:
OrangeJuleas (07-12-2013)
Old 07-12-2013, 07:08 PM   #3
OrangeJuleas
OrangeJuleas's Avatar
How simple is this? I would look into getting something like this as well (will keep it looking fairly stock as well).
I'm not insane, in fact I'm kinda rational, when I be asking y'all, "Where did all the passion go?"
OrangeJuleas is offline   Reply With Quote
Old 07-12-2013, 07:11 PM   #4
Tim_Asphalt_FRS
Is it fast? No.
No different than any other speaker install. They just need to be shallow mount so the window doesn't hit the speaker on the way down.
Old 07-12-2013, 08:32 PM   #5
BRZnut
Drives: BRZ DGM Limited
How to they sound compared to stock??
Old 07-12-2013, 08:47 PM   #6
mashal
DADA
mashal's Avatar
Drives: 2013
Window doesn't even get close to where the speaker sits. I ran the window up and down when I was doing the install to make sure of this .
mashal is offline   Reply With Quote
Old 07-12-2013, 09:39 PM   #7
Z86
Drives: 86 GTS Auto in Pegasus White
You won't get "direct plug and play". The stock speakers have this funky plastic mounting bracket and the stock holes are not in "normal" positions. You could drill new holes in you door.... shudder....
So a couple of things that you should consider. You'll need a mounting bracket. You could buy one of those crappy black adjustable plastic ones, or get one that's custom made for the car like
http://www.subaruaudio.net/subaru-sp...nd-scion-fr-s/
Or you could make your own.
The second thing to consider and really the reason you are doing this, is you want your new speakers to push up against the door trim - this seals the speaker and pushes ALL the sound out into your car where you want it. The factory speakers actually do this. If you do that your mid bass will bang.
Oh, and while you have the door trim off, I'd put in some sound deadening
Z86 is offline   Reply With Quote
The Following User Says Thank You to Z86 For This Useful Post:
PatrickSAN (04-03-2014)
Old 07-12-2013, 10:03 PM   #8
BlackyRose
Any new brackets or drilling required?
Old 07-14-2013, 08:23 PM   #9
zenzsh
Drives: 2013 Subaru BRZ Sport-Tech in White
Installed these today: http://www.futureshop.ca/en-CA/produ...rchPageIndex=1
The plastic bracket was a little small for the hole cut for the stock speakers, but I ended up fastening 2/3 screws and double side taped the the last hole that didn't quite line up. This set also comes with crossovers which I managed to fit inside the door panel with relative ease. This set does not come with wiring (between speakers and crossover). I used stock wiring to the head unit.
I removed the stock tweeters from the stock white adapter, attached the new tweeters to the same base, so I could attach the new tweeters without messing around with wiring. I did not connect the New tweeters to the crossover ... As well it was all the way inside the door.
Overall, great sound. Door speakers have a very heavy low end. They do not distort or rattle like the stock speakers. I did not upgrade the stock amp, and still sounds great.
Hope this helps!
zenzsh is offline   Reply With Quote
Old 07-29-2013, 06:46 PM   #10
RIPTRD71
RIPTRD71's Avatar
Drives: Raven FR-S 6MT
I to have the same question as him. I was already looking at [ame="http://www.amazon.com/Infinity-Reference-6032si-Performance-Loudspeaker/dp/B002C8AFEE/ref=sr_1_1?s=electronics&ie=UTF8&qid=1375137464&sr =1-1&keywords=6.5+shallow+mount+speakers"]Amazon.com: Infinity Reference 6032si 6.5-Inch, Shallow Mount High Performance 180-Watt Two-Way Loudspeaker (Pair): Electronics[/ame] and then I saw you had them.
Originally Posted by wootwoot View Post
She's stiff as a goose. I tried yanking out the motor too, that was pretty stiff as well. So.. i'll try the flux capacitor next.
RIPTRD71 is offline   Reply With Quote
The Following User Says Thank You to RIPTRD71 For This Useful Post:
Tim_Asphalt_FRS (07-30-2013)
Old 07-30-2013, 02:42 AM   #11
Tim_Asphalt_FRS
Is it fast? No.
Originally Posted by RIPTRD71 View Post
I to have the same question as him. I was already looking at Amazon.com: Infinity Reference 6032si 6.5-Inch, Shallow Mount High Performance 180-Watt Two-Way Loudspeaker (Pair): Electronics and then I saw you had them.
Nope. Pretty much went right in.
Old 07-30-2013, 03:51 AM   #12
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
Does anyone know what the speaker specs are for the door speakers? Are those infinity's a decent bump or just a small one?
oldpueblo is offline   Reply With Quote
Old 07-30-2013, 05:48 AM   #13
RIPTRD71
RIPTRD71's Avatar
Thanks for the response man. Im going to order those when i get off work! Thanks again!
Front Stage Speaker Replacement - The Right way? Gopherboy6956 Electronics | Audio | NAV | Infotainment 12 03-27-2013 03:39 PM
Good DIY for speaker replacement. ST185RC Electronics | Audio | NAV | Infotainment 5 02-10-2013 02:47 PM
speaker replacement pcporo Electronics | Audio | NAV | Infotainment 6 01-23-2013 02:02 AM
speaker replacement 20valvewynn83 Electronics | Audio | NAV | Infotainment 3 12-12-2012 02:36 AM
Thoughts on ease of speaker replacement? ahausheer Scion FR-S / Toyota 86 GT86 General Forum 36 11-29-2011 11:16 AM
