Old 07-11-2013, 02:51 PM   #1
PHOsho
PERFECT LOW PROFILE TIRE SIZE
Good morning from Los Angeles!
I'm looking to purchase ROTA Grid 18 x 8.5/9.5 +44/+38 for my SWP BRZ and was wondering what the perfect low profile tire size would be.
I was considering 225/35/18 for front and 235/35/18 for rear but after thorough research and browsing through countless numbers of members' build pages, I'm a bit confused on which size to go with...
I'm pretty much split between 35s and 40s due to road safety issues brought up by some of the members but I've never purchased aftermarket wheel/tires before so I'm asking you guys for suggestions and help.
Any suggestions? Any input will be greatly appreciated!
Thanks in advance!
PHOsho is offline   Reply With Quote
Old 07-11-2013, 02:54 PM   #2
FR-S Matt
Using 245/35/18 on 18X9.5's +38. Balances real well and speedometer isn't off. I've got a square setup though for tire rotations, not staggered. Anything meatier requires coilovers and more sidewall tread might cause rubbing.
Old 07-11-2013, 04:13 PM   #3
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
well for starters, why are you going with a stretched tire?
on an 8.5 a 245/40 is square and on a 9.5 a 265/35 is square for hte most part.
if you must stretch them then go with a taller sidewall. however your offset isn't aggressive enough to warrant the need for stretched tires so if i were you i'd go with a 245/40 or a 235/40 front and a 255/35 or a 265/35 rear.
-ivan
Jive Turkey is offline   Reply With Quote
Old 07-11-2013, 06:08 PM   #4
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
I'm running 18x8.5 +38 front 18x9.5 +38 rear with 225/40/18 & 245/35/18 Pilot Super Sports. Lowered on Eibach Sportlines
No rubbing, not much stretch.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 07-12-2013, 02:12 PM   #5
PHOsho
Thanks for all the inputs guys!
Old 07-12-2013, 02:51 PM   #6
knipple
Drives: 2013 Ultramarine Scion FR-S
I'm running 255/40/17 on 17X9 ET +35 on OEM suspension with no rubbing. I have even added a bit of negative camber in the front. The tires I'm running are the BF Goodrich G-Force Rival which has a measured tread of 262 mm.
If you are interested in autocross, the 9.5 in rear wheels will place you in a Street Prepared class, where as if you keep the width of your wheels at or below 9 in with tread width equal to or less than 265 (as printed on the tire, not measured tread width) you'll be in Street Touring Xtreme (STX).
knipple is offline   Reply With Quote
Tire +/- size guide for FR-S/BRZ SpeedR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 52 12-11-2016 01:12 PM
Appropriate tire size for 250-350 whp Tiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 07-12-2013 03:40 PM
Help with Tire Size Sivtec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-12-2013 01:40 AM
225/35/18 Tire Size? stoneman155 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-29-2013 09:09 PM
Tire Size help! J-Money Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-04-2013 01:04 PM
