Old 07-09-2013, 06:24 AM   #1
Alabang 86
Alabang 86's Avatar
Drives: GT86
Spiral Cable Fiasco
I installed a Momo while I was waiting for JPM to cover my OEM wheel.
JPM wheel came back and I installed without paying attention to the position of the spiral cable connectors.
I either spun it too tight or too "open" regardless, the cruise control, horn didn't work, the traction, ABS and airbag dash lights are always on (traction and ABS are 100% off all the time now.)
I guess I spun the spiral cable in the wrong direction too far before installing the wheel.
....at least I had a chance to take it all apart and better understand what's going on in there. Does anyone have a pic of the cable in the correct position?
...my turn...
Alabang 86 is offline   Reply With Quote
Old 07-09-2013, 10:48 AM   #2
schtebie
Drives: CBS BRZ Limited
Is it the cable? Or did you install the wheel off-center? I remember when my wheel was off, it triggered a ton of lights.
schtebie is offline   Reply With Quote
Old 07-09-2013, 11:05 AM   #3
Alabang 86
Alabang 86's Avatar
Drives: GT86
that's a good question but I cannot answer....
off center? not sure what you mean or how I could do that.
...my turn...
Old 07-09-2013, 11:40 AM   #4
schtebie
When I say off-center, I mean - when your wheels are pointed straight, is your steering wheel aligned straight as well?
Old 07-09-2013, 12:27 PM   #5
FRS-Chief
Drives: 2013 FRS
It's the clock spring wire. It should be winded up loosely in the enclosure to allow the wheel to turn with breaking/ripping the wires out. Your's looks fubar and the best best would be to buy a new one. If you are get it back together and it's not binding, take it to the netural position (where your wheels are centered) and spin it 2 and a half turns each way to make sure it won't bind or break again
FRS-Chief is offline   Reply With Quote
Old 07-09-2013, 12:33 PM   #6
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
I agree with others, get a new assembly. Make sure your wheels are straight when you pull the wheel. Install it making sure one of the orange things are visible in the see through window. At least thats what I did when I removed mine.
FRSFirestorm is offline   Reply With Quote
Old 07-09-2013, 12:36 PM   #7
FRS-Chief
Drives: 2013 FRS
it runs everything on your steering wheel, airbag, cruise, horn
Old 07-14-2013, 11:55 AM   #8
Alabang 86
Alabang 86's Avatar
Drives: GT86
that's where I made my mistake, in a hurry to get going I didn't pay attention to this.....
good info......mine is 100% fubar. since you can't see it thought all was ok. new respect, be careful with this assembly.
my new assembly is on order
correct - a lesson learned
...my turn...
Gauge install, dash cluster light cable, Tach RPM cable help... Sportsguy83 Electronics | Audio | NAV | Infotainment 99 08-07-2016 10:36 PM
Supercharged Spiral 86 by ABFLUG Default Scion FR-S / Toyota 86 GT86 General Forum 68 05-16-2014 01:02 PM
ECUTEK cable. Mo707 Engine, Exhaust, Transmission 12 05-12-2013 09:53 AM
What is this cable? Takumi788 Electronics | Audio | NAV | Infotainment 4 04-07-2013 10:17 PM
Ab Flug's "Spiral 86" to debut at Tokyo Auto Salon BPAuto Cosmetic Modification (Interior/Exterior/Lighting) 8 02-25-2013 04:16 AM
