Old 07-05-2013, 10:05 PM   #1
GaDgeT
GaDgeT's Avatar
DIY phone mount
Hey guys,
have been struggling with phone mounting options in my BRZ for about 2mths now, and have finally found a DIY solution.
I am using an iphone 4s for the moment, but clic-on make docks for heaps of different smart phones with the same mounting points.
Parts used:
- Iphone 4s Thru connector holder
- Male to female 30pin iphone cable extender
- 2mm MDF
- Pebble black trim
- Cable ties
Started off with cutting out a ring to sit flush against the drivers side air vent (84mm)
Removed the air vent, cut the top and bottom off the backing piece then soaked in MDF glue to add some strength. Finally trimmed in pebble black vinyl
Pre-drilled the mounting screws for the dock
test fitting together
Fed the iphone cable extender through the back of the air vent
Tucked the cable in behind the dash, back to the HU input
All back together, air vent is now permanently open as I cable tied the mount to the backing plate, and back or air vent to hold all the bits in
Pat on the back for a job well done
GaDgeT is offline   Reply With Quote
Old 07-05-2013, 10:11 PM   #2
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Nice write up! I might go this route myself. I hardly ever use that vent and have been wanting something to mount my s3 during autocrossing for the Torque app. What was the total cost of the build??
Thanks!
supramkivtt2jz is offline   Reply With Quote
Old 07-05-2013, 10:18 PM   #3
GaDgeT
GaDgeT's Avatar
$125 for the dock, $5 for the cable, the rest I had lying around but whole project cost less than $150
Custom phone mount so26 DIY (Do-It-Yourself) Guides 20 11-07-2016 04:15 PM
Ideas for a hidden magnetic phone-mount. MmmDieselFumes Cosmetic Modification (Interior/Exterior/Lighting) 40 05-09-2016 01:14 PM
Phone holder Tim_Asphalt_FRS Cosmetic Modification (Interior/Exterior/Lighting) 79 04-02-2016 03:28 PM
DIY: Making a GoPro camera mount with a GrimmSpeed front plate mount PMok DIY (Do-It-Yourself) Guides 2 06-11-2013 10:58 AM
Phone app. DanoFA20 Site Announcements / Questions / Issues 6 10-22-2012 11:55 PM
