Old 07-05-2013, 02:00 PM   #1
Shit Luck
Drives: red frs
Non traditional intercooler layouts?
anyone trying anything other than a fmic setup?
havent seen any water cooled or v mount style setups yet.
Shit Luck is offline   Reply With Quote
Old 07-05-2013, 02:09 PM   #2
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
I feel like a front mount is the most logical position for a intercooler given the coldest air is on the bottom - for front mounted engines anyway.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 07-05-2013, 02:13 PM   #3
Ryuu0u
(=^・ェ・^=)
Ryuu0u's Avatar
Drives: 2013 FRS, '08 GSXR 600
Someone do a top mount and a subie style hood!
Ryuu0u is offline   Reply With Quote
Old 07-05-2013, 02:30 PM   #4
Shit Luck
Drives: red frs
thats all well and good if you car doesnt have heat issues like ours. the air from the fmic in now hot air flowing over a radiator and possibly and oil cooler. not to mention shortening some of the rediculously long intercooler pipe runs that on our kits.
Old 07-05-2013, 04:54 PM   #5
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
No space under there for a top mount or any other style.
Long piping? Looks about the same length as most front mounts
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 07-05-2013, 05:58 PM   #6
Calum
That Guy
Drives: 2013 asphalt FRS MT
Nameless hinted at a v mount, but certainly hasn't said anything concrete.
The Following User Says Thank You to Calum For This Useful Post:
Sportsguy83 (12-02-2013)
Old 07-05-2013, 06:38 PM   #7
RedLeader
RedLeader's Avatar
Drives: 2013 Firestorm FR-S
I think, at some point, the temperature of the air going over the intercooler isn't AS important as the fact that SOME air is going over the intercooler. Top mounts have a tendancy to heat soak faster, being mounted on top of an already hot engine. I've seen some interesting split intercoolers on Audis, but our car isn't engineered in such a way to make that possible. A V-mount would be cool, but how would it actually mount without a custom front engine cage (ditching the factory bumper beam and front assembly almost completely ala Greddy D1 FRS).
I'd think with an A/W setup, you have a little more freedom in where to mount said heat exchanger, but mostly because the lines running to it are so much smaller. You could do a rear mount setup (in the haunches over the rear wheels) but then you'd have to engineer scoops to get air to it. Unfortunately, front mount seems to be the easiest, most cost effective way to get the job done. Isn't that why most cars have the radiator mounted low and up front, to collect as much air as possible?
The Following User Says Thank You to RedLeader For This Useful Post:
Old 07-05-2013, 06:40 PM   #8
mrk1
Drives: Sterling BRZ Ltd
I think a V-Mount would be awesome on a BRZ. It would be a lot of work but I believe just about anything can be done. I built a V Mount in my GR STI.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following 2 Users Say Thank You to mrk1 For This Useful Post:
Shit Luck (07-05-2013), Sportsguy83 (12-02-2013)
Old 07-05-2013, 07:43 PM   #9
Shit Luck
Drives: red frs
The rad support unbolts so that is a no cut affair. Hood is easy to make an opening in to extract heat and I believe battle version or someone has a tube beam...
It obviously wouldn't be an over the counter solution, but there should be someone willing to try.
Old 07-05-2013, 11:53 PM   #10
fluffy-reindeer-slayer
Drives: fr-s and tc2
here ya go.
fluffy-reindeer-slayer is offline   Reply With Quote
The Following 5 Users Say Thank You to fluffy-reindeer-slayer For This Useful Post:
F1point4 (12-04-2013), glorydays (12-02-2013), Joveen (07-13-2020), Justkiz (12-02-2013), Sportsguy83 (12-02-2013)
Old 07-08-2013, 11:21 AM   #11
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
What turbo kit is that? I think a V mount setup would be really easy on this car. It would come with a new top support since it can be unbolted.
Old 07-08-2013, 01:33 PM   #12
Syldrin
Troll Feeder
Syldrin's Avatar
Drives: boosted scion tc.
Looks like a greddy kit with a personal touch.
Looks to be next to the greddy tc2 as well.
Syldrin is offline   Reply With Quote
Old 07-08-2013, 03:26 PM   #13
mid_life_crisis
Drives: FR-S 10 #103 AT
Someone do water/air damnit.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
The Following User Says Thank You to mid_life_crisis For This Useful Post:
hmong337 (02-07-2014)
Old 07-08-2013, 07:49 PM   #14
Shit Luck
Drives: red frs
i was thinking the avo kit with a v-mount similiar the smax car i posted up top would be easy.
almost no plumbing involved so the spool time would be instant.
How bad is turbo without intercooler? mid_life_crisis Forced Induction 50 06-23-2013 12:57 PM
2010 Les Paul Traditional $1700 ExWhyZer0 Miscellaneous 5 03-11-2013 06:03 PM
Another turbo with but water to air intercooler ahaghshenas Forced Induction 8 09-24-2012 02:22 AM
