Old 07-03-2013, 06:44 AM   #1
Touge86
Touge86's Avatar
Drives: 2013 DGM BRZ M/T
Exclamation Exhaust Issue
So I was up all night installing both the Perrin Catted Front Pipe and Overpipe..both the fp/op went on pretty smoothly and there were 0 leaks coming from both. But then when I went to go line up the front pipe with my m7-catback it sat flush but, there was a leakage coming from the top where the two pipes connected.
My question is, is it alright to drive around 10-20 miles to a reputable exhaust shop and have them fix it up? The leak is happening where the midpipe and frontpipe connect.
Touge86 is offline   Reply With Quote
Old 07-03-2013, 06:54 AM   #2
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Yes, it is alright to drive with a leak between those two pipes. Don't worry about it.
Build Thread
Instagram
Old 07-03-2013, 06:56 AM   #3
troek
troek's Avatar
Drives: 2012 Toyota 86
the only probelm that should cause would be maybe some soot build up and maybe a fried gasket if you drive hard. but i doubt that much wold build up in a 10-20 mile drive.
i had a nut vibrate loose off of my front pipe overpipe connection about 150kms from home on a mountain drive with friends, and i drove it home rather hardly and just replaced the fried gasket. although i dont recommend doing that.
Old 07-03-2013, 07:07 AM   #4
Touge86
Touge86's Avatar
sounds good, thanks for the replies...
Any idea what might be able to fix it? Seems like the m-7 midpipe was made specifically for the OEM frontpipe in that it looks like it requires some sort of donut gasket to prevent leaks.. Problem is the perrin front pipe has flat flanges and so does the M7, so the gasket they provided didn't want to seal out any leaks.
Old 07-03-2013, 07:21 AM   #5
mad_sb
Drives: 2013 Asphalt FR-S
you should have re used the donut gasket from your oem front pipe most likely. This mistake has been make dozens of times by other members.
TCS Issue subaruatheart Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-26-2013 01:28 PM
Anyone has the same issue like me? ShowTime_DW Scion FR-S / Toyota 86 GT86 General Forum 5 04-16-2013 10:23 PM
Serious issue with FRS!!!!. _F-R-S_ Issues | Warranty | Recalls / TSB 16 08-28-2012 10:08 AM
Cel issue Z06tofrs Issues | Warranty | Recalls / TSB 2 08-27-2012 10:13 AM
Anyone having this issue? zoomzoomers BRZ First-Gen (2012+) — General Topics 11 08-09-2012 11:19 PM
