Old 06-28-2013, 06:12 PM   #1
jimmy4thenguyen
Drives: Whiteout FRS
Need opinions please. square v stagger /17x9 vs 18
Hey guys, I just sold my g35 and kept the rims. The rims are SSR Type C 18x8.5/9.5 (drilled to 5x114) (+22 offset i believe)
Option 1: Keep the wheels, spend money on different rubber and spacer w hub conversion
Option 2: Save for something 17x9/5x100 with proper offset?
Can you anyone with 18's chime in on their track experiences? Much appreciated guys!
jimmy4thenguyen is offline   Reply With Quote
Old 06-28-2013, 10:03 PM   #2
n2oinferno
Praise Helix!
n2oinferno's Avatar
If it were me, I'd go for something made for the car. Depends on if you want to chase that hellaflush look I suppose. The thinnest adapters I've seen were +10. So are you going to be able to fit a 8.5/9.5" wide wheel with a +12 offset? I'd imagine you'll need a ton of camber or fender work.
Old 06-28-2013, 10:54 PM   #3
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
18x9.5 +12 will be a bitch to fit. Extreme camber, tire stretch and fender pull. I like stance and everything but for this car, I feel like 17s just work so much better. Specially in the front. I used to run 18s on past cars and once I went to 17s in the front, I never went back.
The big question s what do you want to do with your car? What is your overall goal?
TylerLieberman is offline   Reply With Quote
Wheel Directory: ESM 004 17x9.0 +38 Scott Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 06-26-2017 04:54 AM
17X9 SQUARE OR 18X8.5F AND 18X9.5R DAN_BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 05-03-2013 01:33 PM
Seeking Opinions: 17x9.5 +40 and 245/40/17 B L U E S L A T E Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 02-21-2013 04:07 AM
(Back up!) FS in FL: Drag DR-31 17x9" Square setup 5x100 (or 5x114.3) +38 Kido1986 Wheels and Tires 5 01-10-2013 03:21 PM
FS in FL: Drag DR-31 17x9" Square setup 5x100 (or 5x114.3) +38 GTB/ZR-1 Wheels and Tires 1 12-06-2012 07:22 AM
