Old 06-27-2013, 12:58 PM   #1
foxhu
HID
will installing HID void warranty?
foxhu is offline   Reply With Quote
Old 06-27-2013, 01:06 PM   #2
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
All BRZs sold in the US have HIDs.
The Following User Says Thank You to Draco-REX For This Useful Post:
feedbag (06-27-2013)
Old 06-27-2013, 01:07 PM   #3
foxhu
really? but it doesn't look like the HID that I use to have. so If I wanted brighter I can just change the hid bulb right?
Old 06-27-2013, 01:10 PM   #4
topazsparrow
Drives: slow
If you want it brighter, you're probably going to be brighter than the law allows and blind oncoming traffic..
topazsparrow is offline   Reply With Quote
The Following User Says Thank You to topazsparrow For This Useful Post:
Old 06-27-2013, 01:13 PM   #5
foxhu
well I know but most people in NYC use highbeams on the road and some cars are bright as hell!!! beside with the stock you can't see anything! during rain it's like you don't even have a headlight lol
Old 06-27-2013, 01:14 PM   #6
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
You are probably talking about the color temperature difference as opposed to actual brightness. If your previous bulb looked more blue, then you were likely 6k brightness or above. As a note, stock HID color temperature is 4.5k, and anything past 6k quickly becomes ineffective.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
The Following User Says Thank You to Cjymiller For This Useful Post:
Old 06-27-2013, 01:18 PM   #7
RurumariGhost
Drives: Dark Grey Metallic 2013 BRZ
are you sure your lights are on? because mine throw enough light to illuminate the stop sign a full block away. also check the dial near the fog switch and trunk, if its on 5 your lights are aimed way down
RurumariGhost is offline   Reply With Quote
The Following 2 Users Say Thank You to RurumariGhost For This Useful Post:
Dorb (06-27-2013), feedbag (06-27-2013)
Old 06-27-2013, 01:29 PM   #8
foxhu
#6 yes mine was 6k before and it's white to me. 6k is kinda fine for me. but in NYC I prefer 8k and above because the light seems useless. during a wet road.
#7 I normally put them on 2, now It's on 0 because a lot of drivers from where I live have brighter light than brz, so hey mind as well get a brighter light that you can see when they blind the hell out of your eye than get a dark light and can't see anything.
Old 06-27-2013, 01:37 PM   #9
foxhu
and yes I googled in NYC there is no law against the limitation of the brightness of the light.
Old 06-27-2013, 02:35 PM   #10
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
so drive with your brights on?
Back to original answer, how bright of a bulb do you want? 10k? 15k?
Old 06-27-2013, 02:47 PM   #11
dsgerbc
Drives: BRZ(sold), STI
It's a federal standard.
Stock HIDs are fine. It's just you sit low and that changes the perception. I do think that I see less when it's raining in the dark relative to my previous car with decent halogens. But I think it's not the brightness, it's the seating position and color rendering features of the HIDs.
dsgerbc is offline   Reply With Quote
Old 06-27-2013, 06:43 PM   #12
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
And that ain't bright.
BRZfan is offline   Reply With Quote
Old 06-27-2013, 06:45 PM   #13
BRZfan
BRZfan's Avatar
Don't forget boys and girls, the BRZ has a headlight up/down adjuster on the dash.
Old 06-27-2013, 06:50 PM   #14
BRZfan
BRZfan's Avatar
Do you know that there is a headlight up/down adjustment roller switch on the dash?????
