Old 06-24-2013, 02:40 AM   #1
cdo221
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
Brightest 7440/7443 LED? V-LEDs worth it?
So my turn signals have been converted to amber LEDs for awhile now but this weekend, my girlfriend was driving behind me and commented that my turn signals are hard to see during certain lighting conditions - basically whenever the ambient light is overwhelming, like during sunset or sunrise.
Right now I have the regular 7440 LED replacements - 68 SMDs per bulb. Are there any brighter LEDs I can throw in there? Would a 120 SMD LED be significantly brighter, or would it even fit in the housing?
Most of the LEDs I see online look pretty much the same, like what I have now:
But, I noticed the V-LEDs has some sort of new kind of LED called the V3 Triton:
http://www.vleds.com/bulb/7443-7440-...-led/v3-a.html
Are these significantly better in terms of output? Any other recommendations for improved LED lighting for the turn signals?
cdo221 is offline   Reply With Quote
Old 06-24-2013, 09:00 AM   #2
DIM
It'll definitely be brighter, but you should measure the diameter of the led and the opening of the housing.
DIM is offline   Reply With Quote
The Following User Says Thank You to DIM For This Useful Post:
cdo221 (06-24-2013)
Old 06-24-2013, 10:09 AM   #3
Vten
Drives: Too heavy
I've been wanting to try those vleds triton, but still cant justify to spend $100 for them yet, eventhough I kept buying the cheaper ebay one which ended up cost more than that :P
so from my experience buying LEDs, none of them is actualy brighter than the incandescent bulbs, but my closest one is this :
they're 25W Cree leds , and here's the video :
[ame="http://www.youtube.com/watch?v=Bh3jPud2Jws"]25W cree led vs oem bulbs - YouTube[/ame]
Vten is offline   Reply With Quote
The Following User Says Thank You to Vten For This Useful Post:
cdo221 (06-24-2013)
Old 06-24-2013, 10:10 AM   #4
Kefu
Drives: WRB BRZ
LED's are one directional lights so they wont be as bright as halogen bulbs. What are you trying to achieve by having LED bulbs? If your trying to get rid of the yellow tinge in the reflector housing I would suggest getting the chrome bulbs that blink amber, have in my car and they are just as bright and remove the yellow/orange reflection in the housing.
Kefu is offline   Reply With Quote
The Following User Says Thank You to Kefu For This Useful Post:
cdo221 (06-24-2013)
Old 06-24-2013, 10:24 AM   #5
Vten
Drives: Too heavy
reason to change the oem bulbs to leds is the blink response time ...im a fond of that, quicker on and off rate , vs the incandescents
Old 06-24-2013, 11:37 AM   #6
qoncept
qoncept's Avatar
What good is that if they aren't bright enough?
qoncept is offline   Reply With Quote
Old 06-24-2013, 01:02 PM   #7
Vten
Drives: Too heavy
It's not that bad ... Check the video ! I had friends following me on a super bright days and they have no problem seeing my turn signals .
Old 06-24-2013, 01:04 PM   #8
cdo221
I may end up with just the chrome bulbs as you suggested. I was trying to achieve 1. removal of yellow tinge and 2. syncing all my turn signals. My front turn signals are switchback LEDs and I also converted my sidemarkers to turn signals w/ LEDs as well. The slight fade in and fade out of the incandescent bulbs didn't match.
Safety of the turn signals trumps everything for me so I might just go with the chrome bulbs if there aren't any LEDs that are good enough - I tested the LEDs only in my garage at night and the LEDs actually looked brighter (probably because of the directional light + low ambient lighting). After my girlfriend mentioned it during the day, I tested in the day and realized that high ambient lighting washes out the LEDs a lot in the day.
Thanks for the suggestion about the Cree LEDs. It looks like they still don't quite match the intensity of the incandescant bulbs during the day. Have you noticed the intensity of the LEDs as an issue during the day?
I may end up trying the V-LEDs since they seem like the brightest LEDs around, I'll update the thread if I do. $100 is a bit pricey for a pair of LEDs though, I might just get a set of Crystal Eye tail light replacements completely instead or maybe just settle with the chrome incandescent bulbs.
Old 06-24-2013, 02:05 PM   #9
qoncept
qoncept's Avatar
You can lightly dust the bulb with silver spray paint if you have it laying around and do the same thing. Here's how my WRX looked, and the lamp was just as bright as before.
Old 06-24-2013, 04:11 PM   #10
scioneric
scioneric's Avatar
Drives: Firestorm FR-S
I have V3 switch back from V-led. I am hesitate at first for $100. When I install mine, it is much brighter than I expect!!!! But now they sell it for $139
scioneric is offline   Reply With Quote
Old 06-24-2013, 05:28 PM   #11
Diode Dynamics
Diode Dynamics's Avatar
We sell a hi-power LED for $59.99:
http://www.diodedynamics.com/store/l...gnal-leds.html
Why spend $140 on a pair of bulbs when ours are incredibly bright and we back them with great service and warranties?
PM me if you need more help!
-Nick C.
FR-S / BRZ Turn Signal LEDs! No Resistors! Switchbacks! Plug & Play Install! Diode Dynamics Interior Parts (Incl. Lighting) 158 08-08-2018 06:52 PM
The Best and Brightest Domelight Available Acree Cosmetic Modification (Interior/Exterior/Lighting) 118 08-14-2013 07:20 AM
LEDs!! ft86me Cosmetic Modification (Interior/Exterior/Lighting) 3 02-13-2013 07:50 AM
7443/7444 chrome bulbs lbroskee Cosmetic Modification (Interior/Exterior/Lighting) 11 08-05-2012 11:16 AM
