Old 06-22-2013, 01:12 AM   #1
SuperJimmyK
Drives: Multi colored Scion FR-S
possible hydrolock
Tonight it rained really hard where I live. After work while heading to grab a bite to eat before heading home I stupidly misjudged the depth of the water on the road and before i knew I was to deep to stop and attempt to back out. Causing my car to stall in foot and half deep water. I got the car out of the water and on to dry land and pulled the air filter, it was soaked, and now and just letting it sit until morning.
My question is what me should i do in the morning to prevent further damage.
I plan on changing the oil and pulling spark plugs and seeing if there is any water in there. Is there more i should check?
SuperJimmyK is offline   Reply With Quote
Old 06-22-2013, 01:52 AM   #2
xjohnx
Grip>Slip
xjohnx's Avatar
Might be worth checking with your insurance company to see if it would be covered.
Old 06-22-2013, 02:03 AM   #3
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Change the oil.. Pull the plugs and turn it over.. Put them back in and start it up.. Unless the engine was up in the rpm's then it should be good..
Gixxersixxerman is offline   Reply With Quote
The Following User Says Thank You to Gixxersixxerman For This Useful Post:
Guff (06-23-2013)
Old 06-22-2013, 02:06 AM   #4
SuperJimmyK
will do. thanks
Old 06-22-2013, 02:47 AM   #5
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
"pull the plugs"... that's going to be a challenge.
azian_advanced is offline   Reply With Quote
Old 06-22-2013, 02:51 AM   #6
Gixxersixxerman
There are a couple threads on here that are DIY and not hard at all.. I think a guy changed all his in 30 mins
Old 06-22-2013, 02:37 PM   #7
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
Some insurance companies will cover hydrolock. Good luck.
clayrush is offline   Reply With Quote
Old 06-23-2013, 12:49 PM   #8
SuperJimmyK
Alright, after a few hours a bagging, cursing and making promises to my car I got the spark plugs removed. I let the water drain out for a half hour while i vacuumed the interior. But when i attempted to turn it over to expel all the water the engine would not crank. There is the click of the starter beginning to engage but no cranking.
Any suggestions? Are there any other thing that an amateur mechanic can try, or is it time to call a professional.
Old 06-23-2013, 01:11 PM   #9
ysr50guy
ysr50guy's Avatar
Drives: brz
Your battery might be low in charge, try charging it.
ysr50guy is offline   Reply With Quote
Old 06-23-2013, 01:15 PM   #10
Mikem53
Drives: FR-S 6MT
Ouch... You might have bent something internally in the engine that the starter can't overcome.. This would be bad indeed.. Or your battery is possibly drained and won't turn the engine over..
Mikem53 is offline   Reply With Quote
Old 06-23-2013, 01:40 PM   #11
Gixxersixxerman
I'd try and turn the engine over by hand with a breaker bar and socket on the main pulley.. If it doesn't budge then it's most likely broken something and jammed up.. How high where the RPM's???
Old 06-23-2013, 01:41 PM   #12
jamesm
put a jump box on it and try again, it'll probably turn over unless something electrical got jacked up. in that case you can check all the fuses and use a multimeter to see if the starter motor is getting juice with the key turned. if it's got juice, the motor's probably jacked. if not, it's an open probably from a connector or wire melting or something.
i'm not sure what the chances of damage are with an engine like this, but i've swamped and restarted about a bazillion dirtbikes in my life with hardly any issues.
Old 06-23-2013, 01:47 PM   #13
SuperJimmyK
Battery. That's something i hadn't considered. It's always the obvious things I over look. Thanks i will check that out.
Old 06-23-2013, 01:47 PM   #14
wheelhaus
wheelhaus's Avatar
Just a click would indicate the battery charge is really low. Might have been another effect of getting things soaked, some wires might have been shorted by the water and caused a parasitic drain that killed it.
You could also pull the fuse for the fuel pump(s) when you turn the engine over with the plugs out. This would prevent the ECU from dumping fuel into the cylinders without spark, further flooding it.
wheelhaus is offline   Reply With Quote
