Old 05-31-2013, 11:00 AM   #1
Bullnettles
Drives: Scion FR-S 2013
Driveshaft on a DD FRS
Should I upgrade? I have never had a two piece drive-shaft and it just bugs me. Would you guys say it's worth the swap if I don't autoX my car, but do have a few mods and like to hit the twisties?
Bullnettles is offline   Reply With Quote
Old 05-31-2013, 11:34 AM   #2
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
I just switched to a CF driveshaft and mine is a daily driver. It makes a difference, is it worth $1K I guess that depend on how much money you have sitting around. If you don't have a tune already I would say you'll get more bang for your buck there.
Old 05-31-2013, 11:49 AM   #3
Bullnettles
Eh, not wanting to void the warranty or give them any reason to try. I know that tunes probably help the motor last 98% of the time, but dealers have to cover their asses. Also, I'll be making enough power, so I'm thinking of getting the transfer to the wheels better over more power.
Old 05-31-2013, 12:01 PM   #4
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Cf review
@Bullnettles
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 05-31-2013, 12:21 PM   #5
Bullnettles
Hmm, why would anyone go with the CF over the aluminum if weight savings are the same? Only thing I can think of if will the AL one not clear stock guards?
Old 05-31-2013, 12:42 PM   #6
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
We love ours! And I agree with @Bullnettles , there are mods you can do that will be more noticeable in regards to power, but for the ease of install, warranty, ability to remove it quickly and the fact it will not decrease reliability is a huge plus for me. Plus I just love the way the car feels with a carbon shaft on it!
[ame="http://www.youtube.com/watch?v=DsGJf21uMto"]http://www.youtube.com/watch?v=DsGJf21uMto[/ame]
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 05-31-2013, 12:52 PM   #7
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
What bugs you about a two piece prop? Worried about the carrier bearing orbiting? Does the prop itself seem out of balance?
Chimpo is offline   Reply With Quote
Old 05-31-2013, 01:07 PM   #8
Zaneman
Drives: 2013 BRZ limited
If I'm not mistaken CF absorbs more energy then aluminum thereby providing a smoother transfer of energy that can be felt by the user.
Zaneman is offline   Reply With Quote
Old 05-31-2013, 01:12 PM   #9
Bullnettles
Ah, that would make sense. This will not be a max-effort build, so I'm thinking I'll go with the AL if it will fit within reason.
Always didn't because of power loss, now hearing about the 6 cyl Mustangs exploding (albeit, at speeds higher than their governor), I just don't like that, haha.
Old 05-31-2013, 01:14 PM   #10
Bullnettles
Hair of research showed this. If the AL fits, definitely going that route.
http://forums.nasioc.com/forums/show....php?t=2271059
Old 05-31-2013, 01:33 PM   #11
AJ PwR
AJ PwR's Avatar
Drives: R35 R56 CZ4A ZC6
Send a message via ICQ to AJ PwR Send a message via AIM to AJ PwR Send a message via MSN to AJ PwR
I don't know if it is just me, I have the PST drive shaft. It's a quality built piece but I notice a vibration. It's acceptable at low rpm ranges but at 5th gear 4000rpm, you can feel it ! It vibrates though the seat then up to my butt. The feeling is like sitting on a message chair.
I installed a diff brace and that increased the vibration even more so I have to take it off. To ensure the diff brace is causing the vibration so I installed it to my friends BRZ and he doesn't get the vibration
I ended up put the stock one back on and the vibration went away ! I am not sure if it's me or my car or something to do with the shaft !
Does anyone has the same issue ?
AJ PwR is offline   Reply With Quote
Old 05-31-2013, 01:35 PM   #12
OrbitalEllipses
Drives: Attitude
That's not comforting, even if it's a "non-issue" I can't stand vibrations.
Old 05-31-2013, 01:38 PM   #13
Bullnettles
Whoa, definitely not comforting...
Old 05-31-2013, 01:47 PM   #14
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
Power loss? I'm assuming your talking about the prop twisting under load, and that will be a property of the material it's made of and a "tiny" amount of slip in the center joint splines. *side note, I'm guessing on that, will look when done how this prop is put together* Look at a car with an IDS and equal length halfshafts. Obviously this is done to help mitigate torque steer induced by the a longer one piece design twisting more and esentially not allowing one wheel to keep up with the other (although there may be packaging / cost influences as well).
And any prop spun fast enough is eventually going to hit it's critical speed and potentially fail. That's not the fault of it being a two piece design, that's the fault of the operator being stupid by incorrect use or poor choice of tube diameter/thickness. On a side note, I've heard NASCAR goes through the critical speed of their props, but they go through it quickly enough (getting out of the natural freq range) that it's not a problem... plus it probably is replace after every race...
Don't misunderstand me, carbon fiber prop is choice and you'll see improvement, but there is nothing wrong with what came in your car either.
Driveshaft Shop Carbon Fiber Shafts Explained Driveshaft Shop Engine, Exhaust, Transmission 121 11-17-2017 11:57 AM
CF driveshaft review Adeets Engine, Exhaust, Transmission 9 05-22-2013 03:00 PM
stock driveshaft for sale evilconcarne999 Transmission and Driveline 0 03-12-2013 02:11 AM
The Driveshaft Shop Custom Axles and Shafts Sportsguy83 Engine, Exhaust, Transmission 26 01-11-2013 04:55 PM
Automatic Carbon Fiber Driveshaft? Yes! RallySport Direct Engine, Exhaust, Transmission 13 12-15-2012 12:40 AM
