Drives: 2013 Raven Scion FRS
Has anybody ported and polished there throttle body yet?
Going to be installing my fa20 CAI this weel and I am thinking about port and polishing my throttle while I have it all apart. Just wanna here ur thoughts.
Drives: '15 STi Ltd
I don't see the point. It's not exactly rough. Maybe you could try and get some sort of taper to it, but you're still going to have the factory throttle plate in there as a bottle neck. Past that, it's already a 3" throttle body, which isn't exactly small for a NA 2.0L engine.
The other thing is that I don't have a degree in fluid dynamics, so unless you do (or a flow bench to prove out what you did), you don't really know that what you're doing is helping ( I understand ports on a head vs intake manifold didn't match up, and/or it was a rough cast surface). In the end you probably won't hurt anything, but I wouldn't expect anything either. On a side note, Cusco offers an overbored one, and I think there are more options out there as well. |
*their
Ultramarine 2013 Scion FR-S 6MT
| The Following 14 Users Say Thank You to CaptainSlow For This Useful Post: | Akari (08-09-2014), deucethemoose (07-13-2013), Flat Black VW (04-18-2018), HotRodPA (04-18-2018), JB86'd (08-09-2014), jebuwh (08-09-2014), Opposed (06-18-2013), Plxdjake89 (08-09-2014), R2RO (07-16-2013), raven1231 (08-10-2014), slicktop (07-31-2013), SloS14 (07-13-2013), Snake (04-19-2018), WithNolock (08-09-2014) |
#4 | |
PROUD OF BOXER
Drives: Raven FR-S
im more concerned what the intake ports look like. im sure gasket matching them would net something.
| The Following User Says Thank You to supramkivtt2jz For This Useful Post: | strat61caster (04-18-2018) |
Thupercharged
I've had some bad experiences with porting throttlebodies on OBDII engines.
Depending on the porting job, you may get DTC codes due to discrepancies between throttle position and actual airflow measured by the MAF. I was chasing several DTC codes in a previous car that turned out to be due to a ported OEM throttle body. Was confirmed not to be a sensor/electronics issue, just a difference in airflow that the ECU said "nope" to and threw several DTC codes. The throttle response was better with the ported throttle body, but after switching to the OEM unit I got used to it after several drives and it actually felt better and less "twitchy"
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
| The Following User Says Thank You to DJCarbine For This Useful Post: | Jtymay92 (06-18-2013) |
Drives: 2013 Ultramarine FRS
If you plan on really building the engine then go for it, but if its an NA street car(intake/exhaust) its not worth it. I put a larger bore TB on my Ford Probe GT back in high school and it made absolutely zero difference on the butt dyno...that was $400 well spent
Drives: 2013 Subaru BRZ & 99' Ford Explorer
i want to see this happen. i cant believe that no one has done this yet!
i did it on my 1998 4.0 sohc v6 explorer sport. IT IS NIGHT AND DAY WHEN YOU SWAP THE STOCK TB FOR THE P&P TB... (on the 4.0 sohc v6) even tho its a totally different engine. i might get another stock brz tb to have p&p. i will try to find a used one maybe from a totaled one. if i can find one. this car has no balls. we need to start modding does anyone know how much a new throttle body is? |
#9 | ||
Drives: 2013 Asphalt FR-S
As DJcarbine mentioned, the ecu might get pissy, especially given the drive by wire system. Then again, it might be perfectly happy. However, given the way the drive by wire works (torque request vs calculated torque) you would probably only notice any gains at WOT. No that that is a bad thing.
~Namaste~ |
#10 | |
Drives: '13 Ultramarine
#12 |
The price of the Cusco TB is crazy.
For less than 1/5 the cost of that, a person could have their stock TB (or a core from a wrecked car, etc) ported/bored, polished, 1/2 shafted, and knife edged. I'm surprised I haven't seen more discussion on this especially in the F.I. threads.
#13 |
There's absolutely no need for it. The TB on this car is huge already. Very, very low hp/$ mod.
#14 |
Drives: waiting on a 2021...
If you get this done, don't forget to pick up one of these:
http://kalecoauto.com/index.php?main...&products_id=8 I'd say it was almost mandatory....
2016 4Runner Tail edition
2020 Camry 2020 RAV4 2013 Chevy 3500 4x4 Duramax 1999 Ford F250 Powerstroke, the tow rig 1969 Mustang, the fast car....(: |
| Cusco Throttle Body? | track_warrior | Engine, Exhaust, Transmission | 66 | 06-28-2016 06:28 PM |
| Dirty throttle body | AVOturboworld | Engine, Exhaust, Transmission | 11 | 05-11-2016 10:58 AM |
| Heated throttle body? | Turdinator | Engine, Exhaust, Transmission | 19 | 04-06-2014 11:21 AM |
| YR-Advance Throttle Body | ANREX | Engine, Exhaust, Transmission | 9 | 10-30-2012 01:45 AM |
