Old 06-17-2013, 09:58 PM   #1
orangeblue
Drives: Whiteout
Toyota is Replacing My Transmission
Since car was new, 1st to 2nd shift was always balky. At higher RPM, shift into 4th, either from 3rd or 5th, would result in a really disturbing metallic crunching noise. Could be cruising at 50mph in 5th gear, clutch to the floor and 4th would crunch.
Tried replacing fluid with Redline, no improvement. Car has between 7500 and 8000 miles.
Anyway, my Dad just got a new FR-S, and the shifting is perfectly smooth. I took it into my local dealership on Saturday and told them about the issue. Basically it started as a "this must just be how the transmission is," and changed to "something is totally FUBAR" after comparing to the new car.
The dealership put in a call to corporate Toyota, who asked them to drive my car back-to-back with another FR-S to check for a difference. Service department called me back today to say they were told to replace the transmission and that it had been ordered. Should have the car back later this week.
orangeblue is offline   Reply With Quote
Old 06-18-2013, 02:03 AM   #2
SoCal_86
テック
SoCal_86's Avatar
Drives: 85 Toyota Corolla GTS 13 Scion FRS
I too have this issue. I should be calling my dealer soon!
SoCal_86 is offline   Reply With Quote
Old 06-18-2013, 02:08 AM   #3
Yruyur
Yruyur's Avatar
Had mine replaced about 8 months ago for the same issue. If anything it helped me with my lemon law case.
Old 06-18-2013, 02:35 AM   #4
PANDA86
Old School Status
Drives: .
what was the issue or cause for malfunction?
PANDA86 is offline   Reply With Quote
Old 06-18-2013, 07:58 AM   #5
whtchocla7e
Drives: 2013 FR-S Hot Lava
Going to the dealership today. I'm tired of the crunchy gears. Thanks for the heads up.
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 06-18-2013, 08:59 AM   #6
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
For all the people who got their transmission replaced under warranty, what is the last 4 of your VIN#?
LeeMaster is offline   Reply With Quote
Old 06-18-2013, 09:07 AM   #7
#87
I usually post drunk
#87's Avatar
I have a less than 1000 VIN and trans no problems so far at 15k street miles, not exactly granny shifted
#87 is offline   Reply With Quote
Old 06-18-2013, 10:41 AM   #8
FRiSson
Drives: FR-S MT
How is the "metallic crunching noise" different from the "balky" quality of the 1-2 shift? Is there a sound associated with it, or just a feel?
FRiSson is offline   Reply With Quote
Old 06-18-2013, 11:19 AM   #9
waterbison777
I had my transmission replaced by longo toyota a few months ago as well. It was the same issue as the OP; metallic crunching sounds shifting into 4th from either 3rd or 5th gear. The crunching was definitely more prevalent when shifting above 6k rpm, but you could feel it at lower rpms as well. They said that my transmission had a deformed synchro ring and replaced the entire tranny free of charge.
waterbison777 is offline   Reply With Quote
Old 06-18-2013, 11:40 AM   #10
LeeMaster
Red wine
Hmmm... time to go test drive an FRS and make comparisons....
Old 06-18-2013, 11:46 AM   #11
Yruyur
Yruyur's Avatar
Don't know. 4th was grinding out loud. They were prepared to charge me for a new transmission if they found my clutch was burnt. It was not. Toyota corporate had them replace clutch flywheel and tranny.
Old 06-18-2013, 11:47 AM   #12
radroach
Drives: car
Should I have the syncro rings checked before 30,000 miles?
Are the syncro rings replaceable instead of the whole transmission?
Old 06-18-2013, 12:08 PM   #13
orangeblue
Drives: Whiteout
Balky just meant that the shift had resistance to it; it wouldn't smoothly engage 2nd gear. The crunching noise in 4th gear was definitely a loud metal-on-metal noise. 2nd didn't have a noise.
Old 06-18-2013, 12:35 PM   #14
OrbitalEllipses
Drives: Attitude
Sooo those of us that may have done a burnout or two won't get transmission warranty work? Cute.
Replacing badges Pneub BRZ First-Gen (2012+) — General Topics 1 05-30-2013 02:52 PM
anyone have DIY for replacing OEM HU?? mbh1101 DIY (Do-It-Yourself) Guides 2 01-27-2013 12:18 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
Toyota FT-86 transmission is this it? 4agze Engine, Exhaust, Transmission 65 03-24-2011 08:08 PM
