Old 06-14-2013, 04:51 PM   #1
Chinadian
Chinadian's Avatar
Drives: FRS Whiteout
Are these HID lights?
So I have been noticing really nice lights on luxury sedans/suvs. They are white light and really focused lights. Usually when I see HIDs on most cars they are very dispersed kind of light (ie. the whole area of where the bulb is is white) and not shaped.
I was wondering if anyone knows what I am talking about and if those are HIDs? Because I want the focused look of HIDs, not the very dispersed look. I also think that part of the dispersed look is from the camera/picture vs in real life.
I am also a noob, don't know much about anything.
TThat would be what I call "dispersed" white light
vs something like this, more defined shape of the light (don't know if its HID or not.
even this BRZ lights look "dispersed"
Chinadian is offline   Reply With Quote
Old 06-14-2013, 04:56 PM   #2
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
most of the time they have a "defined shape" but when taking a picture the camera overexposes the headlights, making them look dispersed.
Normally you will only get a "dispersed" look if you have hid's in non-projector housings(ie, old style reflectors-any car without projectors).
However, the projectors in our cars(frs) were not really made for HID's, so although they will fit, it can cause glare above the cutoff line, which is hazardous for other drivers. Many members on here have bent down the squirrel finders inside the stock housings to try and limit the amount of light above the cutoff line, but the effectiveness is perspective based(you might think its fine, but a hardcore headlight guy/driver coming the other direction as you might not think its fine)
Old 06-14-2013, 04:57 PM   #3
continuecrushing
if the defined/dispersed look explanation doesn't make sense, I'll take some photos of my car tonight to show that its usually based on angle/exposure.
The Following User Says Thank You to continuecrushing For This Useful Post:
Chinadian (06-15-2013)
Old 06-14-2013, 05:08 PM   #4
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Technically, all the above mentioned ARE High Intensity Discharged lights. The difference in what makes them dispersed vs non-dispersed are the Projectors themselves. You can buy any projector HID from any local junkyard and modify them to fit your vehicle. A quick google search you can find a few DIY with people who uses 06-08 TSX projectors.
From top to bottom
1) Dispersed HID
2) semi-dispersed HID
3) Projector HID(defined)
ps
Your stock FRS headlight with an HID kit would probably look more like #1 from picture above.
LeeMaster is offline   Reply With Quote
The Following 5 Users Say Thank You to LeeMaster For This Useful Post:
Chinadian (06-15-2013), Cjymiller (06-14-2013), Enraged21 (06-16-2013), Mistergreggles82 (06-15-2013), suaveflooder (06-18-2013)
Old 06-15-2013, 06:58 PM   #5
Chinadian
Chinadian's Avatar
Yes please.
Old 06-15-2013, 07:02 PM   #6
Chinadian
Chinadian's Avatar
From top to bottom
1) Dispersed HID
ps
Do you have shots of the actual look of the car in the 3 various settings?. By looking at the 3 lights, definately the last one looks alot better. But i really want to see how the car itself looks.
Also, are luxury cars' "projectors" nicer then? because (I am assuming) that middle aged women driving a bmw, with nice white lights, probably didnt modify her lights (add HIDs)?
The Following User Says Thank You to Chinadian For This Useful Post:
Old 06-16-2013, 03:09 PM   #7
KI_ZN6
KI_ZN6's Avatar
Checkout our thread and visit our online store to learn more about our HID Conversion Kits for the FR-S =)
http://www.ft86club.com/forums/showthread.php?t=8500
www.hidpowerhouse.com
KI_ZN6 is offline   Reply With Quote
Old 06-16-2013, 03:38 PM   #8
Vten
Drives: Too heavy
The last picture seem sharper because of the upgraded clear lenses versus the oem lenses .... The clear lenses definately will give a sharper beam output .
Had a retrofitted headlights on my old ride and very happy with the result .
Vten is offline   Reply With Quote
The Following User Says Thank You to Vten For This Useful Post:
Chinadian (06-17-2013)
Old 06-17-2013, 02:28 PM   #9
LeeMaster
Red wine
I do not have shots of the actual car unfortunately, I'll take a picture with my BRZ light soon and then hopefully somebody with an HID kit for the FRS can chime in as well.
All factory cars that comes with HID are required to have projectors. Which is why old ladies/men who drives nice BMWs, AUDIs and Acuras have nice white light that dont make you go blind. Regular cars with halogen bulbs dont need projectors because their light output is lower so they only use a semi-projected unit to keep from blinding oncoming drivers and to see better at night.
The Following User Says Thank You to LeeMaster For This Useful Post:
Old 06-17-2013, 02:36 PM   #10
Sbeezy
Drives: 2001 ZX2, WRBP BRZ (soon hopefully)
Not all. There were some earlier cars that came with d2r xenons from the factory first gen mini was one of few until the 2005.5 facelift then BMW switched to d2s xenons.
Sent from my SPH-L710 using Tapatalk 2
Sbeezy is offline   Reply With Quote
Old 06-17-2013, 02:37 PM   #11
Yruyur
Yruyur's Avatar
Get an hid retrofit kit. Link in my signature.
Retrofit kit includes the correct projectors to focus the beam for hids.
The cutoff is amazing. Its addicting watching the cutoff at night. Bright white then absolute pitch black an inch above that.
The Following User Says Thank You to Yruyur For This Useful Post:
Old 06-17-2013, 02:38 PM   #12
nalc
Drives: 13 BRZ Limited 6MT GBS
This isn't true. There are some cars (2002-2003 Maxima, some older Acuras) that came with reflector HIDs from the factory, although these were never as popular as projector HIDs, and fell out of style a decade ago.
And the converse is also true - plenty of cars, including the FRS, have halogen projectors.
Fundamentally, a projector is a less efficient device than a reflector, but it allows more control over the beam. They work well with HIDs because a HID bulb produces a lot of light. Projector optics allow you to manage glare a lot better and create more ideal beam pattern, and you've got so much output that you can afford to take the efficiency hit. With reflector optics, you've got less control over your beam, but a higher efficiency, so it's a better match for a dimmer halogen bulb.
nalc is offline   Reply With Quote
Old 06-17-2013, 02:45 PM   #13
Richard Cranium
Ted
Drives: Raven FR-S
ps
^This is completely incorrect. I'll post a photo tonight, but the factory FR-S lens' w/an aftermarket HID kit looks more somewhere in between photos 2 and 3, not even remotely like photo 1.
2013 Scion FR-S - Sideways and Smiling
Bone-yard: 2010 Toyota Tacoma, 2008 Honda Civic SI, 2002 Audi A4 1.8T Stage 3 K04, 1999 Honda Civic SI
Richard Cranium is offline   Reply With Quote
The Following User Says Thank You to Richard Cranium For This Useful Post:
gatorbushmen (06-17-2013)
Old 06-17-2013, 07:13 PM   #14
Chinadian
Chinadian's Avatar
So is FRS the "projector" or "reflector"?
Thanks for the input everyone!
**PHASTEK** HID Headlights, Reverse Lights, Fog Lights (FR-S / BRZ) PhastekSport Exterior Parts - Lighting 18 07-09-2014 08:42 PM
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 09:38 PM
FRS HID lights? easybreazy Cosmetic Modification (Interior/Exterior/Lighting) 84 08-27-2012 11:21 PM
Lights ashtray BRZ First-Gen (2012+) — General Topics 4 06-19-2012 12:30 PM
Fog lights on with parking/running lights possible? BMWDavid BRZ First-Gen (2012+) — General Topics 1 06-16-2012 08:29 PM
