What's your opinion about spacers
Hey guys, so I'm thinking about running spacers (20F & 25R). What's everyones opinion about them, yey or nay? My FRS is my daily with occasional spirited drive. Are they safe?
Also what brand would y'all recommend? THANKS!!! |
Destroyer of Tires
Drives: 2001 Honda Accord, 1997 Lexus ES300
As long as you get quality parts, spacers are fine. Make sure they are hubcentric. I'm assuming you're going to get the kind with pressed in studs?
| The Following User Says Thank You to Redstar For This Useful Post: | Toyobaru808 (06-14-2013) |
NASA SpecE30 Racer
I would go with the H&R spacers. In general I am not a fan of spacers and prefer properly speced wheel sizes and offsets, but I understand that sometimes that is not possible when dealing with rare wheels. If you wanted additional safety, I would ditch the cheap studs that come with the large spacers and go with some ARPs instead.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following 2 Users Say Thank You to King Tut For This Useful Post: | suaveflooder (06-14-2013), Toyobaru808 (06-14-2013) |
head of infinite swagger
Drives: 2013 FR-S 6MT
Just buy name brand and you should be good. Eibach also makes them.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater 2000 Silverstone M5 6MT - SOLD 2013 Ultramarine FR-S 6MT - Car Journal - SOLD 2004 AlpineWhite M3 6MT - SOLD |
Spacers are fine as long as they dont effect the thread in which the lug nuts go on. Adaptors are also fine as long as precautions are made to ensure the assembly is secure without issues of it loosening. The key issue usually with adaptors though are that instead of one assembly(namely wheels and lug nuts) you are looking at double the assembly which adds weight, and the possibility of loosening. But as long as you are aware of what you are doing, there shouldnt be problems.
Drives: LR BRZ Limited
i wouldnt be able to sleep easy or push my car as hard because i'd know there is something else that could go wrong between my wheel and my hub
| The Following User Says Thank You to DuMa For This Useful Post: | yoshiharadesign (06-14-2013) |
I think your worries are well warranted simply because you are essentially adding another assembly onto another assembly... That being said, and on the flip side, there are so many components on machinery that require double assemblies that it shouldnt be a problem... It would mean a personal preference at that poiint...
Drives: '24 GR86
Powered by max also makes some good spacers. Slip ons and bolts ons are all hub centric and vehicle specific. They have numerous options for the brz/frs
| The Following User Says Thank You to TylerLieberman For This Useful Post: | Toyobaru808 (06-14-2013) |
#10 |
Drives: 2006 STi
i had a set of 15mm ichibas crack on me while torquing the lugs on the existing studs, very scary. I Believe project Kics makes forged spacers
| The Following User Says Thank You to SLICVIC For This Useful Post: | Toyobaru808 (06-15-2013) |
#11 |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I went with H&R 20mmF and 30mmR and haven't had any problems with them yet but just had them on for about 500mi. I'd be lying if I were to tell you I have as much confidence in my current wheels with spacers as with my stocks, but given some more time and miles I think I'll be fine. I was extremely meticulous about torquing all nuts to the right spec. One thing is for sure I really like how my +48 offset 7.5" wheels look with the spacers now cause I'm very flush (if you're into that sort of thing). Performance wise I feel it drives slightly different with a wider base but haven't decided if I like it better or not.
| The Following User Says Thank You to mit_peid For This Useful Post: | Toyobaru808 (06-15-2013) |
#12 |
Just a dude
Drives: Scion FR-S 2013
Lachute Performance makes hq spacers for the twins as well.
#13 |
Drives: '23 BRZ
Not a fan of spacers. They change scrub radius up front, lower wheel rates, and aesthetically I hate the look of skinnyish wheels/tires shoved further outboard. I'd put spacer $$$ toward wider wheels with reasonable offsets and wider stickier tires.
#14 | |
Drives: 2013 Scion FRS WhiteOut
This
![]() Winnipeg, Manitoba |
| DGM Opinion | soontobrz | BRZ First-Gen (2012+) — General Topics | 4 | 02-03-2013 08:31 AM |
| Your opinion? | xAgentzero13 | BRZ Photos, Videos, Wallpapers, Gallery Forum | 73 | 09-11-2012 06:20 AM |
| Opinion - 86 to FR-S | GaN-MaN | AUSTRALIA | 38 | 06-13-2012 01:36 AM |
