Old 06-13-2013, 09:05 PM   #1
jacobzking
Drives: White FRS
Where is BRZ navigation antenna? Part number? Pics?
anyone know where the separate GPS antenna is located for the BRZ nav? anyone have pics of it, or pics of the connector? part number? thanks!
jacobzking is offline   Reply With Quote
Old 06-14-2013, 12:24 AM   #2
37
degrees
37's Avatar
Drives: 6MT BRZ
Electrical/Sensors > Electrical > Body Electrical > Antenna & Radio
or
Electrical > Electrical > Antenna
depending on the dealer's site.
37 is offline   Reply With Quote
Old 06-14-2013, 12:38 AM   #3
jacobzking
Drives: White FRS
or
thats the radio antenna, the sat nav has its own antenna mounted somewhere under the dash. here's a pic of it i found on ebay... would still like to know EXACTLY where it goes under the dash and a part number would be great.
Old 06-14-2013, 02:20 AM   #4
37
degrees
37's Avatar
Drives: 6MT BRZ
That piece installs around the head unit. You can see it at the top of the cutout in this photo: http://image.automobilemag.com/f/rev...cement.JPG.jpg
Photo originally from this article: http://www.automobilemag.com/reviews...anuary_update/
I couldn't find that in any of the parts diagrams though. It might be considered part of the display unit.
Old 06-14-2013, 08:04 AM   #5
Skippman
Skippman's Avatar
Drives: GBS BRZ Limited
The BRZ antenna contains the GPS antenna. It's in the roof, not in the dash. That's only on the FRS where the GPS system is optional. I'm sorry I don't know the specific part number.
Skippman is offline   Reply With Quote
Old 06-14-2013, 08:24 AM   #6
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Correct, the BRZ antenna base houses the GPS reciever. If you compare the BRZ antenna base to the FR-S you'll see that it is MUCH larger.
Old 06-14-2013, 09:51 AM   #7
37
degrees
37's Avatar
Drives: 6MT BRZ
Actually, the BRZ antenna contains the satellite radio and radio antennas, not navigation. I mistook the request above and thought the OP was looking for the radio antenna. The navigation antenna mounts directly above the display unit in the dash. The link I posted above shows this.
The US is the only country to have satellite radio, hence why our BRZs get a unique exterior antenna base.
Old 09-23-2021, 11:02 AM   #8
covance
Drives: 2015 BRZ series.blue
On a brz, can I disconnect the BRZ GPS antenna and still have the stock headunit be functional?
covance is offline   Reply With Quote
Old 09-23-2021, 01:06 PM   #9
Grady
Grady's Avatar
No the GPS will quit working.
Old 09-27-2021, 10:21 AM   #10
covance
So if the GPS doesnt work, it won't let me do radio/bluetooth etc either? I would be fine with the GPS part not functional as long as everything else was still operational.
I need an NZ pic and a part number of the AC delete 000 Racing AUSTRALIA 3 04-02-2013 09:11 PM
need a part number the Red Devil Scion FR-S / Toyota 86 GT86 General Forum 0 12-12-2012 12:42 PM
I need a part number Bones36 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-01-2012 05:25 PM
Part number or name for this clip TrickyFrenchman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 07-16-2012 10:50 PM
Part Number for this DriftEightSix AUSTRALIA 20 06-25-2012 08:30 PM
