Old 06-13-2013, 04:58 PM   #1
kaybee123
Drives: Scion FR-S
Can't read ECU
Hey,
I've been installing a vortech supercharger kit with a new fuel pump, new injectors and ecutek tune.
I installed everything, flashed the ECU with a tune and started it up... it worked!!!
BUT!
It started leaking gas from around the fuel pump so I quickly stopped the car from running.
I took out the fuel pump, fixed the leak and now it's back in but now the car won't start!
When I put the key in to "ON", I don't hear the pump working.
- Because I tested the pump separately, I know it works.
- I also tested the wiring going to the pump separately (the wiring in the fuel canister) and it works.
- I checked the fuses and they seem ok. I replaced one that seemed to have blown.
Now I'm trying to reconnect to the OBD connector to 'reflash' the ECU and I can't even connect to the ECU!!!
--> So... car won't crank, I don't hear the fuel pump working when it's on the "ON" position.
--> Can't access the ECU from ECUtek Dongle anymore! (Related I suppose)
Help?! The car started fine ONCE before when there was a fuel leak.
Thanks
kaybee123 is offline   Reply With Quote
Old 06-13-2013, 06:26 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Are you getting any power at all? Relay gone maybe? Definitely seems electrical and the ECU isn't powering up.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-13-2013, 06:36 PM   #3
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
disconnect the battery for 15 minutes and connect it baack again
Old 06-13-2013, 11:14 PM   #4
kaybee123
Drives: Scion FR-S
I'm getting power, everything lights up when I'm on "ON" but nothing happens when I turn the key.
if you love music read this ric342 Electronics | Audio | NAV | Infotainment 14 10-13-2012 07:32 PM
how do you read the last digits of the VIN? pr086 Scion FR-S / Toyota 86 GT86 General Forum 2 09-04-2012 06:00 PM
Want to track your FR-S? Read this for my perspective! Rejor11 Tracking / Autocross / HPDE / Drifting 9 08-03-2012 02:19 PM
Can anyone read Dutch? Buggy51 BRZ First-Gen (2012+) — General Topics 14 12-28-2011 09:48 PM
Toyota READ THIS Mr.Jay Off-Topic Lounge [WARNING: NO POLITICS] 1 12-09-2011 12:13 AM
