Old 02-26-2013, 08:13 PM   #1
cruzinbill
Drives: Argento 6spd FR-S
Anyone running this size?
Anyone running a 275/40/17 rear tire? I'm still searching figured I'd post it tho as I'm not seeing it yet.
cruzinbill is offline   Reply With Quote
Old 02-26-2013, 08:41 PM   #2
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Dont see a reason why it wouldn't fit, Id like to see it. Most people going FI needing that wide of a tire are opting for 18's
Tansey86 is offline   Reply With Quote
Old 02-26-2013, 08:53 PM   #3
Z3D
I am getting some 18X10s square and some 275s soon, I will have some updates.
Z3D is offline   Reply With Quote
Old 02-26-2013, 08:57 PM   #4
cruzinbill
meh Im still between 17s and 18s still not sure if I feel like paying 18" prices, was more worried about the width I'm wanting right now.
Ive heard 255 is the widest up front without rubbing at full lock can anyone confirm this?
Old 02-26-2013, 09:00 PM   #5
Tansey86
Tansey86's Avatar
It comes down to springs/coilovers and how of an offset you can run. If you want the widest tire possible, youre gonna want coilovers for extra inside clearence and a high offset +45 or maybe even higher to tuck the wheen so you wont have to run a crazy amount of camber to get it to fit. Unless your okay with a bit of wheel gap. 255 is a bit wide up front, if going staggerd and want to run 275 id suggest 245 up front.
The Following User Says Thank You to Tansey86 For This Useful Post:
cruzinbill (02-26-2013)
Old 02-26-2013, 09:15 PM   #6
Tansey86
Tansey86's Avatar
I dont see the point of these guys going 265 wide tire with sub 40 offset, then lowering it so much that they need to run like 4 degrees of camber and lost so much surface area. Seems counter intuitive.
Anyone running a tune? swift996 Mid-Atlantic 9 02-04-2013 10:43 AM
Anyone running 225/45/17 tires? How do you like that size so far? Chimpo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-01-2012 02:24 PM
Think all tires of the same size ARE the same size? Draco-REX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-26-2012 08:41 PM
Sport Touring class. What tire/wheel size are you running? UncleFester Tracking / Autocross / HPDE / Drifting 7 07-19-2012 03:56 PM
What size wheels do you plan on running? poormans_LFA Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 51 04-28-2012 05:30 PM
